Darren Donovan
I have E-7 schedule, I don't think it's available anymore. I've had it since 2007. Do I have to switch to E-6?
Thanks,
Thanks,
PG&E Residential Time of Use Rates Changes Coming November 11th, 2015
http://luminalt.com/2015/11/11/pge-residential-time-of-use-rates-changes-coming/
“Upon the first day that Schedule E-TOU-A and E-TOU-B become available for enrollment in 2016, Schedule E-6 shall be closed to new customers.” – PG&E Settlement Agreement in A.13-04-014 adopted last week by the CPUC. PG&E will be ending its solar friendly E-6 and E-7 time of use (“TOU”) rate schedules in 2016 and launching new TOU rate schedules. See the bottom of this post for a comparison of E-6, E-7 and the new E-TOU-A hours. The new E-TOU rate schedules are expected to be less beneficial for solar customers. For an explanation of how TOU rates work with solar, click here.
The exact date has not yet been set for the launch of the new TOU rates. We do know it will be in early 2016 and no later than June 1, 2016. We also know that you will not be able to go on E-6 once the new TOU rates are available to customers. That means you need to be on E-6 before the new TOU rates become available. In other words, when the new TOU rates go into effect, it will be too late to switch to E-6.
Those on E-6 before the new TOU rates go into effect will be allowed to remain on E-6 until January 1, 2023. If you are on E-6 you can stop reading this. Should you switch to E-6 before it closes?
If you are not on E-6 and have a solar system or will be installing a solar system in the next year, now is the time to decide whether you should change your rate schedule to E-6.
E-6 is the most common time of use rate schedule for solar customers and is the most beneficial rate schedule for many who have solar. It may, however, not be the best rate schedule for you. Call PG&E at (800) 743-5000 to discuss your rate options and decide whether moving to E-6 is the best option for you.
Important information for those on E-7. E-7, a solar friendly TOU rate schedule which has been closed to new customers for a number of years, will be eliminated. PG&E will migrate customers on E-7 to E-TOU-A. If you are on E-7, consider changing your rate with PG&E to E-6. Customers on E-7 who have submitted an E-6 rate change request one month prior to the date on which E-6 is closed to new customers, will be allowed to move to E-6.
Comparison of E-7, E-6 and E-TOU Hours:
E-7 Hours
PEAK: noon to 6pm Monday through Friday, All Year
OFF-PEAK: all other hours
E-6 Hours
Summer (May 1 through October 31)
PEAK: 1pm to 7pm Monday through Friday
PARTIAL-PEAK: 10am to 1pm and 7pm to 9pm Monday through Friday
plus 5pm to 8pm Saturday and Sunday
OFF-PEAK: All other times, including Holidays
Winter (November 1 through April 30)
PARTIAL-PEAK: 5pm to 8pm Monday through Friday
E-TOU-A
PEAK: 3pm to 8pm Monday through Friday
It seesm that E6 is not available after March 2016..... So if I enroll before this date how long can a customer stay on the E6 plan?
Hard to say how they notify anyone these days. We don't get a paper bill and certainly did not notice anything on the last statement about the E7 plan going away. I did a full scan of our December bill and used March as a search term too and there is nothing stated about E7 going away in March.I find it hard to believe that PG&E is not required to notify those who are on E7 that the above is going to happen.
When I was investigating Solar, I heard many different stories about the way PG&E buys back the daytime power. The solar sales rep claims that they pay market rate during the day (roughly $0.36/KWh) and then you buy it back for cheap at night, which multiplies the KWh you generate during the day by a factor of 2-3. However, that seems to be the old net-metering method.
I also heard that you simply get KWh credits during the day to offset your KWh usage at night. Any extra credits you have at the end of the year can be rolled to the next year or "trued up" for $0.03/KWh, which is well below the cost of solar. Therefore, you do not want to over provision your solar system.
I never got a really straight answer from anyone as to which of these scenarios is true. And I did not buy the solar system so I have no actual experience with net-metering. But we did get the Model S and we did switch to the EV rate and our power cost has gone down substantially despite the massive increase in usage. I also moved our pool pumps to run 11pm-7am to take advantage of the low EV rates.
Besides the basic, home electrical needs (and mostly LED lamps, of course), my home has a water well pump, septic system pumps, and pumps to pressurize the water. Over time I've converted my home to now be heated (and cooled) by an electric heat pump, dryer converted to electric, went from a LEAF to an electric RAV4 (handling even more of my yearly driving), my girlfriend got an electric RAV4 as well and, as of today, I just replaced my propane cooktop with induction (electric)! All that's left to convert is the water heater still burning propane (not counting a couple of gas fireplaces). As a result, each year my excess production has become less and less and will probably reach zero this year or next.
Have you compared E-6 to EV A/B rate plans with solar?
Impressive conversion to electric! I am also curious about using a heat pump.
I have had an induction stove for 8 years. Best cooktop I've ever had. Faster and more responsive than gas, and energy efficient.
Sounds like we have similar goals. How is the electric heat pump working for your heat? I've been considering a move in that direction. My gas cooktop cutout is an odd shape, so I can't find an induction cooktop to replace it at this point. I'm going to wait until we remodel the kitchen in a few years. Drives me nuts, though.
[FONT=Courier New]Miele KM6375 35 19.32
Miele KM6370 34.50 20.375 2500/3850
Miele KM5773 36.125 19.6875 3350/3850
Thermidor CIT365KBB 34.75 19.88 2600/3700/4600
Thermidor CIT36XKBB 34.75 19.88 3600/4600
Bosch 800 Series 34.75 19.88 3400/4500
Bosch 500 Series 34.75 19.88
Bosch Benchmark 34.88 19.88
KitchenAid KICU569XBL 33.06 19.31
= Jenn-Air JIC4536XB
GE Cafe Series 33.875 19.125 3700, better controls
GE Profile 9036DJBB 33.875 19.125 3700
Wolf Transitional 35 19.5 2600/3700
Wolf Contemporary 35 19.5 2600/3700
Electrolux 35.875 20.375 3700/4800
Bertazzoni 33.875 19.6875 3000[/FONT]
If I had to chose again I would NOT go with a heat pump. I have split systems in my home since 1987. Prior to that we had another house with a heat pump. If the temp goes below about 45 degrees and you have any measureable amount of humidity, you are going to be spending all of your money on defrosting and heat strips. Plus the heat is not very warm and they are noisey in the areas of the house adjacent to the outside units.
Thanks so much for the feedback. I'm definitely on board with the heat pump. I will ask for a price and get the ball rolling on that.
My cutout is 21" deep for my cooktop. Sadly, your excellent table confirms that I'm stuck replacing the cooktop or waiting on a remodel. I'm pretty eager, regardless.
Thanks again!
Well, perhaps the systems have improved? I don't have heat strips (because I still have my original propane furnace as backup) and while I frequently see high humidity outside (coastal fog in the Santa Cruz hills here), I don't have any trouble with humidity in the house or this defrosting issue you mention. And it definitely blows very warm air.
Noise-wise, I was told that these Lennox XP17 units were the quietest heat pumps on the market. Here's an article I just found on the topic:
http://604goodguy.com/blog/2013/02/08/lennox-vs-trane-vs-carrier-heat-pumps-which-brand-is-best/
