jeffro01
Anyone heard when PG&E is going to make the new "Schedule EV" rates available? Their website still says "late spring" but....
Jeff
Jeff
Just talked with them and they said July 1.Anyone heard when PG&E is going to make the new "Schedule EV" rates available? Their website still says "late spring" but....
Jeff
The time periods for this EV rate kept bouncing around until the end.
What are the new time periods, then? Do you have a link?
And then there's the tiering. If you pull alot of juice, the newer rates might be better since there's no tiering penalty. However, for lighter use, the tiered rates could be advantageous.
The new EV plan is a no-brainer for me considering that even before I got my Model S, I was already in the topmost tier on the E1 plan - and therefore all my Model S charging was costing me 35c/kWh. With the EV plan, as long as I charge in off-peak hours, I will pay 10c/kWh. And just to be sure, I modeled my entire past few months usage thoroughly with the new EV rates to confirm my overall savings.
I rent so solar is not an option and with 2 EVs we are into Tier 5. In June we used 1.2Mwh off-peak so we're looking at ~$40/month in savings from off-peak while peak and part-peak are roughly a wash (we are into Tier 5 for both of those too).@strider, what is your rationale for switching? The new rates do kick in an extra hour of Off-Peak charging at night (starting at 11pm instead of midnight), but on weekends, the Part-Peak 3pm-7pm times becomes a full On-Peak.
Second Meter and Panel: Customers who select the EV-B rate will need a second meter and electrical panel. Customers could opt to replace their existing panel with a dual meter panel although this is generally more costly. The electrician will arrange an inspection and obtain a permit from the city and/or county. In addition to the electrician's installation costs for the second panel, PG&E will bill you $100 for the second meter.
I am in the process of installing solar and was told by SolarCity that with a solar system you are better off keeping the E9A rate plan as rates during the daylight hours are higher when you will selling back to the grid. But he indicated PG&E will eventually eliminate the E9A rate plan and migrate everyone to the EV plan.
