I received the 20.2.1 firmware three days ago and my M3 had not slept since the update. This is the firmware with the new dog mode texting and the auto screen nighttime mode dimmer default. I have checked all the settings to make sure the update did not change any setting that would use more power.
Cabin overheat protection OFF
Sentry OFF
Removed Dashcam USB stick
Smartphone Bluetooth disabled and Tesla App terminated
I have made no setting changes in the past few weeks.
I rebooted using the two steering wheel buttons and again with the brake applied.
Until until about two firmware updates back, I could always hear the pumps running AND the charge port clicking anytime my M3 was not sleeping. Now after a variable amount of time the pumps make no noise but the charge port clicks continuous anytime the car is awake.
Anytime the charge port is clicking the contactors are closed and the car is NOT sleeping. Not sure why the charge port latch is being cycled during warmer none winter months (needless wear and tear)? The computer knows what the ambient temp is and at temps above 50 degrees F (which is almost the entire year parked in my garage) should not need to cycle the charge port lock?
Since there are times I only drive once a week around 30 miles, this high phantom drain represents the lions share of the household power cost. At 24 miles of phantom drain that is about 6KW usage per day. Own typical power usage before I purchased my M3 was about 10KW per day or 300KW per month year round. The ambient temps in my garage currently varies between 70F and 80F, this should not require any passive or active cooling, correct?
Is anyone else seeing very high Phantom Drains since the latest firmware update???? I am at a loss as to why the car will not sleep.
Thanks Very Much in Advance!!
Regards, Ron
Sentry OFF
Regards, Ron
