Phantom drain out of control
Discussion in 'Model X' started by mattack4000, Jan 9, 2020.
  1. mattack4000
    mattack4000 Active Member
    Is anyone seeing a good 4-6% in phantom drain? I understand it is colder out, but 4-6% a day seems like a lot. What is the car doing! I am not sure if it is just this build. I am on 50.1
  2. mswlogo
    mswlogo Well-Known Member
    MA, NH
    Sentry?
    Summon Standby?
  3. ToddS
    ToddS Member
    Jupiter, FL
    I think it's Sentry.
    While parked at the airport, mine was losing 4-6% per day.
  4. glide
    glide Active Member
    4-6%? That’s it?
    Where do you live, sunny California?
    • Disagree x 1
  5. mswlogo
    MA, NH
    Is this a joke?
    4-6% a day is ridiculous. I lose 1 mile every 2 days. Which equates to about 0.15% a day. And it’s 17F outside right now (but my car gets to sleep in a cozy 45F garage).
    You don’t lose miles just sitting asleep in the cold unless it’s insanely cold. Like below -26F.
    Sentry and Summon will kill your battery.
    6% is 20 miles on my car, that’s more than my commute. That would be like an ICE SUV losing a gallon of fuel a day.
    • Disagree x 1
  6. Soey22
    Soey22 Member
    Fort Erie, ON, Canada
    Update to 40.50.7
  7. glide
    glide Active Member
    Clearly you don’t have a pre-facelift model S or early Model X
  8. Corsair
    Corsair Member
    South Surrey, BC , Canada
    Mine's about 4% loss/day with sentry mode on & summon off with BlackVue 1CH recording. (ver 50.6)
  9. azred
    azred Active Member
    Chandler, AZ
    This is a tough dilemma. Sentry and possible YouTube fame or a topped off battery?
    • Funny x 2
  10. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    It seems like beside Sentry (and/or 3rd party dashcams) that people could clarify which of these options they are using:
  11. mattack4000
    The option isn’t available on mcu2. Sentry wasn’t running as the car had 5%, went to 3% in 5 hours
  12. DoctorVenkman
    DoctorVenkman Member
    Los Angeles
    I also experienced significant phantom drain recently over the past few weeks. It's been about 3-5% overnight; normal is <1%. No sentry mode and no summon assist.
    I looked through every option to see if there was anything that would obviously be causing it but I couldn't find anything.
  13. rush6410
    rush6410 Member
    Montgomery TX
    Pre-conditioning and Energy saving off always connected with cause drain.
    Third-party apps that keep your car awake could be a problem. There are options in Teslafi that allow the car to sleep. If they are not set correctly, your car will never sleep causing drain.
  14. mswlogo
    MA, NH
    You did not mention if you have Summon Standby on which will drain the battery.
    Nor did you mention if you run apps.
