Had the phantom indication again yesterday, but found light depress either way on the indicator stalk did nothing (for 2018 S). Will try full detent matching indication next time to see if the return to centre works.
It's terrible. Counter intuitive, and you need to use *just* the right amount of pressure or it won't cancel, or if you go the opposite direction and use a little too much pressure, you indicate the opposite way. Do Tesla ever test anything they implement?
light press either way to cancel works the exact same way as my old BMW so it is a kind of standard
However I was able to reprogram the BMW to give 5 blinks on a light press - worked much better than 3 and rarely got into a flip-flopping fight.
2018 S, full detent stalk indication and return to centre in direction of phantom indicating didn't work either. Only trying that in the opposite direction left to try.
