There are a number of delivery checklists, search the forums. Here is an example:
2022 Model S: Delivery Checklist
My car had 9 issues I found on delivery, I still took delivery, but made sure the delivery person noted them all. I also took photos. I found more issues later. I fixed some issues myself, Tesla fixed the rest.
Issue with new vehicle delivered 3/21/2022
1 - The lower trunk covers are missing, both large and small, as noted by delivery person.
Fixed by SC
2 - The wiper blades make a loud knocking sound when they return to their resting place.
Fixed by SC
3 - The frunk gap on the left side is higher than the right. It looks odd, yet delivery person says it is in spec?
Fixed by SC
4 - I am unable to record dashcam footage while driving, not even the honk option works.
Fixed after first software update
5 - I occasional get an error that says the dashcam drive is not large enough. It is the default 128GB drive that came with the car.
6 - I can't see my safety score in the app even though I enabled the opt in for FSD?
Just started working, even before software update
7 - My car is stuck on an old build and not receiving any new updates.
Eventually got the update. Apparently fixes for my different chips needed to make it to mainline first.
8 - The service section of the app tells me to install a software update, however my car says it is up to date.
Went away after first software update
9 - Missing front license plate cover
Fixed by SC
Issues found hew hours after delivery that I fixed myself
1 - Plastic clips for seals around doors not all pushed in correctly. Pushed them in all the way.
1 - Wiper fluid pipes to both wipers not connect! Fluid went into frunk instead of windshield. Connected tubes.
New issue 3/31/2022
1 - Right front door handle does not always retract and then blinks a light. It snaps back with a light push, or on its own after a while. E.g. when driving I hear this loud noise that sounds like something hitting the side of the car.
- "Fixed" by SC, however they moved handle to low, now it pops on open, every time! Did they even bother testing it?
- Fixed for real by mobile tech by correctly centering the door handle.
New issue 4/25/2022
1 - Right back door opens itself either when opening or closing the trunk. Happened three times so far.
- SC could not repro, so did not try fix it. Said I must file a service request next time it happens. I did, they sent mobile tech.
- Mobile tech inspected it. They could not find anything. Said I should file another service request and they will look at logs??
- Fixed it myself when I discovered the emergency release tab was stuck between carpet and metal causing the cable to be under constant tension. They never bothered to look at it! I know since the hidden push out in the carpet was still intact. (Why is the emergency release hidden??)
