Johan
Ex got M3 in the divorce, waiting for EU Model Y!
The BMS really doesn't seem involved in the actual charging in the Model S and battery. The Model S charger itself, as visible in some photos others have posted, just feeds the battery high voltage to the main connector. The same with supercharging. So, sanely applying a charge voltage to the pack should charge it fine.
So basically as long as you can control the voltage being fed you can make sure the battery doesn't overcharge. As for making you own "crude" BMS I guess you could monitor the voltage of the modules individually, since they each have their own wiring, and perhaps instead of having a system that "bleeds off" modules to balance all the time instead you could manually,a couple of times per year (?), charge the pack up, then bleed off module per module as required to balance the pack, using something that loads/draws appropriate current? My guess is this would be good enough for stationary use, since you won't be neither supercharging nor drawing hundreds of Amps? Also perhaps active cooling will be unnescessary for your intended use and climate?
