glhs272
Unnamed plug faced villian
Isn't it obvious that it is? This has been discussed previously in the Roadster threads. I think it's the Achilles heel of a Tesla battery pack. Most of our batteries will die that way - with most of the cells still in good shape and a few bricks in bad condition. For 2 years I've been trying to think of a good engineering solution to this but haven't come up with anything affordable or cheap enough.
Yes it is sorta obvious or at least I have been thinking about this failure mode. I was hoping I was wrong. It has been discussed that the Tesla pack is immune to single cell failures, but that only seems to be true for catastrophic single cell failures (i.e. sudden short) where the cell fuse blows. If the BMS system were capable of active balancing (i.e. charge shuttling) it might be theoretically able to cope with this type of failure by keeping the brick voltages up by drawing from other bricks. From a whole pack perspective it would appear that the pack self discharges a little quicker, but might be hardly noticeable. But if the BMS is only capable of bleeding off excess voltage from bricks through resistors and not actually capable pushing charge to individual bricks via dc to dc converters, then yes the pack is going to die this way. If it appeared that the pack was starting to die by doing this, it could be fixable if you were willing to open up the pack and trace down the bad brick/module. Either replace the module as a whole or dive even deeper and try to find the bad cell. Once you found the bad brick or group of 74 cells in parallel, it would be a challenge to figure out which cell is bad. But if you could, you could just snip the fuse and take it out of the system. Perhaps if you charged the group of 74 cells and then snipped all of the fuses and then measure voltage at each cell and find the bad one, then solder on new fuses to all the good cells. Or perhaps if you were to charge the 74 cell group and image the pack with a FLIR camera, perhaps the bad cell would be noticeable by being hotter than the rest. Then just snip the bad cell. Of course all of this would have to be done before the rest of the cells get too low in voltage and get damaged.
