dhanson865
Are all common plastics transparent at the frequency that the radar uses? "Clear" in the visible spectrum doesn't imply transparency at other frequencies.
What materials are transparent to radar? Weatherproofing a radar gun | Physics Forums - The Fusion of Science and Community
Had a chance to test the materials this morning, to my surprise the detector continued working with all of them. The first test piece was 10mm 'armoured' clear acrylic normally used in the windows on yachts. The second was 6mm clear 'cast acrylic sheet' made by Altuglas and the final piece was 1mm Clear HIPS (high impact polystyrene).
What blocks GPS signals? Radar waves (specifically X,K, and Ka bands)? - Ars Technica OpenForum
Plastics and other materials can be all over the board when it comes to attenuation. The figure you're looking for is 'loss tangent'. Lower loss tangent == less loss == better signal strength.
Dielectric Constant, Strength, Loss Tangent - RF Cafe
To answer your original question: You should be just fine with a thin piece of just about any plastic, as long as nothing metallic is involved. Anything HDPE, LDPE, PC, or ABS should pose no problem.
Keep the plastic as thin as you can possibly get away with, and leave at least 1-2 inches of space between the plastic and the radar unit to avoid detuning the internal antennas.
So keep it thin, keep it carbon free and metal free, and keep it an inch or so in front of the radar.
