Pictures of Sector 111 RaceView CF mirrors on the Roadster?
Discussion in 'Roadster 2008-2012' started by wiztecy, Sep 26, 2014.
Tags:
  1. wiztecy
    wiztecy Active Member
    Curious if anyone has installed the RaceView mirrors on their Roadster and have pics. Curious what your impression is of them and view from the drivers seat compared to stock. They do look to have less wind drag.
  2. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
    Dennis can you show us these RaceView mirrors? (and if possibile also the link?)
  3. wiztecy
    From the "raceVIEW Mirrors do not fit" thread it appears they do from post #4 & #5 (pasted below). Curious if Jaff got around to buy/install them... I don't don't know the mounting plate they're taking about, possibly the raceView supplied plate?
  4. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    I probably never showed a photo...... I'll try to do that as soon as I get home from my current trip. Yes there is a mounting plate which uses the three screw holes left by the stock mirrors and then the singular stem for the race view mirror is mounted to that plate. then I did not use race views Miroirs but instead a Japanese motorcycle mirror that I found via a lotus form. I'll really try to post some pics because they look great on the car.
  5. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Apparently not... this was posted elsewhere on the forum today:
  6. felixtb
    Lausanne, CH
    Pour Jaff was probably conned by Carbon One and never
    got his mirrors back....... as quite a few of us were at the time...... :-( Probably never got around to get a new pair after that......
  7. Jaff
    Jaff Active Member
    Grimsby, Canada
    #9 Jaff, Sep 27, 2014
    ...nope...
    ...Felix is right...they became a "casualty" of the Carbon One fiasco...:rolleyes:
    The CF weave did not match the Roadster's weave so I sent them to John to be wrapped...apparently Klingons absconded with 'em enroute to my door...
  8. wiztecy
    Sounds like that company took its toll on people. Bum deal literally.
    I'm interested in the Race mirrors for that they do appear to have less of a foot print for drag. Would be nice to have a quick swap on it, possibly running only one side (driver's) on long trips running the smallest legal mirror which sounds like the motorcycle one. I'm also looking to button up the aerodynamics for the bottom of the Roadster, by the wheels on the bottom trays but don't want to drill:
    And also want to play around with a longer rear CF diffuser to lower the drag. Something like this but where it pushes out from the rear at least 3-4" so there's limited tu
    Also the front 1.5 splitter I feel could have a better lip to push the air out around the Roadster better as well as more down and away from the belly pan for better efficiency. Looks crude and lot all the functional as currently implemented.
    I personally think we have some room to make the drag coefficient even better on the Roadster.
  9. Jaff
    Jaff Active Member
    Grimsby, Canada
    #11 Jaff, Sep 29, 2014
    Hey Dennis, if you do proceed with the Raceview mirrors, please post some pics...I still might think of installing them, but would be interested in your thoughts and musings if you go that route.
    Cheers!
    One caveat with the raceview mirrors...I wonder how much "actual" mirror area you lose with the raceview vs. stock...in traffic, you really have to depend on your side mirrors to safely drive the Roadster...I really wouldn't want to trade wind resistance for "too little mirror" to be effective...
  10. felixtb
    Lausanne, CH
    pics of my race view mirror base install with japanese motorcycle mirrors
    here are some pics that I have promise since a year or two :crying:
  11. wiztecy
    Those mirrors look excellent on the Roadster! Great decision to swap out the mirror body for the motorcycle one. Where did you find the motorcycle mirrors?
    Thanks for posting the pics.
  12. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Wow those look great. Could you please post a link to those mirrors?
    What is involved in installing them?
  13. felixtb
    Lausanne, CH
    sorry for another late answer. I had help from TESLA Zurich to install them But they simply said never again. It is the base plate for the race-view mirrors from sector 111. To fit they had to be drilled and screwed from the outside instead of from the inside as indicated in the instructions.... they just don't fit that way. Then I swapped out the squarish race-view mirrors for these japanese motorcycle mirrors and their fixed stems. The stems are however, ok legally as they do not stick out outside the body of the car. The mirrors and their stems I got on this website and are the type 4 mirrors.
    Moto Works | Magical Racing Parts | Racer Replica Mirrors It was a little bit of mix and match but worked great in the end and I still love them. Good luck if you decide to do this!
