Piece fell off charge port door
steilkurve
866
266
Montreal, Canada
Hey all. Came back from work and was plugging in my September 2018 P3D and a small part fell off the charge port door. Not broken. Simply looks like the glue that held it in place dried out. Charge port still seems to operate normally. Photos are attached. I feel like I could glue it back and avoid a SvC visit but then again I’m not sure what the piece does. Anyone else got this?
araxara
S-P85#3,218 X-LR M3AWD
May 11, 2012
1,012
380
Tucson, AZ
Believe it or not, that small piece is responsible for allowing you to push on the charge port door to open it. There are other threads talking about it.
When mine fell off, I was lucky to find it on the floor and re-glued it back on. It hasn’t fallen off in 5 months now. I don’t remember what kind of glue I used, but it was thick and sticky.
Reactions: Dre78
AndrewE
5
Shelburne, VT
I had the same thing happen, but it fell off somewhere where I did not see it or grab it. So I had a mobile tach come out to address it. The solution was to replace the entire charging door. I assumed the part could be reglued, but Tesla put in a whole new door. It only took about 45 minutes and it has been all good since.
Reactions: Dre78
aronth5
Long Time Follower
May 8, 2010
2,667
1,391
Boston Suburb
I had the same thing happen months ago and still have the piece. Never saw it mentioned until this thread and haven't noticed any problems with the charging door.
Maybe because I never push on the charging door to open it. So just glued it back on tonight and voila it works!
steilkurve
866
266
Montreal, Canada
Thanks. Planning on gluing mine back as well. What kind of glue did you use?
DonTom
85
33
Reno, NV and Auburn, CA
I had no idea I could open the charge door by pushing in on it. I've never opened it that way.
But I just checked mine, my plastic thingie is still in there.
But if I did lose it, I would not even notice the difference so I wouldn't even care.
I normally use the button on the Wall Connector plug or I use the FOB.
-Don- Auburn, CA
03DSG
2,142
2,445
Ontario
I tested mine yesterday with my fingernail and it came right off easily. Cleaned everything with alcohol and reattached using KrazyGlue. Worked great. Charge door works from screen, APP, charge handle and a direct push.
