You really don't mind having different tyres front and rear?
Different pressures each corner as well, I hope (to balance out the different handling characteristics)I use a different tyre on each corner. Saves having to cut one up.
I understand entirely the argument for having tyres of the same type and age on the same axle. but I have never understood why having the same tyre front and rear is of any significance? can you enlighten me?You really don't mind having different tyres front and rear?
Because if they are significantly different in the way they perform, especially in different conditions, it will induce an imbalance.I understand entirely the argument for having tyres of the same type and age on the same axle. but I have never understood why having the same tyre front and rear is of any significance? can you enlighten me?
I have tried it , many times.Different levels of grip, slip angles, sidewall stiffness. I think the problem is that you can't predict how the handling will be influenced in a situation where you need maximum grip/handling ... it could be OK or it might be life threatening ... and you'll never know until you try it!!
Here's an interesting video: Can You Mix Tyres Across Axles - Tyre Tests and Reviews @ Tyre Reviews
In your example, putting brand new tyres on one axle with very worn tyres on the other will cause a slight imbalance because of the difference in tread depths, but I wouldn't be too concerned about that in most cases. In a high performance car with stiff suspension, it starts to become more of an issue.I've certainly never replaced a pair of worn out tyres on one axle and found the handling got worse or less predicable.
The video is interesting but its message is more don't buy cheap tyres at all and don't mix cheap and expensive both of which I would agree with but its notable that when he mixed 2 different brands of similar quality it was basically fine and had zero impact on his lap time.
What suprises me is most drivers faith that less than 1 sqft of rubber contacting the road (however premium it is) will sort out whatever you do with a 2 ton lump of metal. This is particularly obvious in snow when all of the Range Rover drivers near me realise that physics beats 4 wheel drive when they try to stop going down hill too fast
