splurging for a stripped down 100D vs the 75D with some options,
PUP is standard now so if are referring to purchasing without EAP and larger tires ..I would still go 100d I’d budget can allow ...beyond passing speeds on freeway you need to take into consideration your real usable range ...assuming you are charging to 90% and only running down to 20% ...you are not getting full use of the 75 battery ..the car is heavy ..I also live in SoCal and the density of chargers makes it easier ..but also they are more crowded ...if you are not used to driving an EV and just want to use it as u did your normal ICE (ie drive same speeds ~75mph, use heater in winter ..blast AC ) than the bigger battery is way to go ..you will find yourself driving this more as well. I did drive a S 75D and that has reasonable range but a lot lighter car
