General rule of thumb is that every 100 lbs added increased 1/4 mile time by 0.1 seconds. Looking at the 1/4 time specs alone 9.23 vs 9.9 and the X Plaid weight 600 lbs more than the S, this adds up.
However, looking at the 0-60 time, the difference is 0.5 seconds which means most of the difference in the 1/4 time is just 0-60 and that after that, the X is only 0.17 seconds slower to the 1/4 finish than the S....which does NOT add up. So either the Plaid can't make the 1/4 in 9.9, OR the 0-60 must be faster OR the Plaid X battery must run higher amps sometime after reaching 60 in order to hit 9.9 seconds.
Thoughts?
Thoughts?
