mcvaughan
Doesn't look hard at all honestly, but since I have to have an alignment done anyway I'll have my shop do it all.How hard is this to install for someone who is handy but never done this? Or take to a shop?
Same story here.
I had a very slow leak in my right rear tire. It was losing about 1psi every 3 days. I took it to a local shop. They did a leak test and everything looked fine.
On a road trip, I get a notification that the right rear is getting low. It’s down to 30psi and dropping about 1psi every 4 minutes. I figure it is a puncture and the object is still there.
I make it to a supercharger and take a look. The attached image is what I see. The tread/sidewall junction has separated. The crazy part is the tread is still in fine shape.
So, I go down the rabbit hole and end up on this thread.
I have installed a new set of tires and ordered the N2itive Alignment kit.
Based on the discussion - and the solution N2itive has come up with - the factory camber/toe settings and weak suspension components are to blame.
How do we get Tesla on board with a fix, or is there a better way to get this issue sorted out?
Anyone know any way to get word to Tesla?
They responded very quickly when I reached out through their support page: Contact us formNot really. All their communication channels are broken. How did you reach out to Michelin? I'll probably have to do the same thing soon.
File a claim with Michelin (assuming you’re on the 21” wheels?) and they should generate an order for two new rear tires under the warranty. Al, you’ll pay for is mounting and balancing.Does anyone have any insight on why our rear tires are slowly losing air? My right rear is slowly losing air. It seems to be a common problem, before the tires fail.
Hope you saved the old tires?Same story here.
Not alignment—tire defect in design or manufacture….I got in touch with Michelin. They requested that I take the damaged tire to one of their approved shops for an inspection.
Immediately when I showed the inspector the tire he said, "You got a major alignment issue." He is reporting this information back to Michelin.
I am hoping that Michelin will get this information to Tesla and we can kick up some dust this way.
I have attached a few more images showing how drastically the "misalignment" wore the tire.
One way to get more data/info is if those that have had this issue, throw your vehicle on an alignment rack and let’s analyze the numbers.
I’ve seen some excessive toe out which would definitely not help with the delaminating. Add to that some excessive negative camber and it gets even more concerning.
Teslas allowable specs for alignment values are extremely wide in nature.
For the air leak? Mine haven't delaminated yet.File a claim with Michelin (assuming you’re on the 21” wheels?) and they should generate an order for two new rear tires under the warranty. Al, you’ll pay for is mounting and balancing.
details on many pages here….
Do NOT dispose of your old tires until the Michelin rep has seen them, however.
This is just not true. The Model S has been doing this to tires ever since it was released. Now that these cars have even more torque, this is becoming even more prevalent.Not alignment—tire defect in design or manufacture….
please save your tires for Michelin rep review.
Yes.For the air leak? Mine haven't delaminated yet.
The sad part is, adding alignment fixtures to a subframe is probably a $5 change, but it would require like, inspecting the alignment at the factory and setting it and doing a bit of a test drive to make sure, and that's an extra hour of assembly time, and we can't have that. Multilink rear cars have had cam bolts on them for centuries, maybe even millenia. Entire ostensibly "less advanced" cars that sold for less than the aggregate cost of the destroyed tires posted in this thread so far. It's so bizarre, almost as bizarre as no brake ducts on a car that can put enough energy into brakes to melt a small moon (the brake duct thing isn't just Tesla, ubersedans everywhere are being delivered duct/scoopless to squeeze out an extra five bucks of parts commonality with base cars and five one thousandths of a MPG). Thank ricky bobby's sweet 8lb 5oz baby jesus for the aftermarketThis is probably the best photo showing exactly what some of us have been trying to say, related to it being an alignment issue, not a tire failure. thanks for sharing it.
As for a "fix" from Tesla, a six-figure performance car should come with a $500 part from the factory to adjust camber. It's that simple. The second part to the equation concerning at what suspension level do you align the car to from the factory, is the one I don't have an answer for. Does the low alignment running at medium height at below 70mph change anything significantly? Would it be better to do a proper alignment at medium and let it induce a bit more camber when it goes into low? No clue.
