So far the fix has been holding. No issues. It took two service appointments to get fixed. The second one they actually removed the bash/skid plate cleaned debris and retorqued…first appointment was just retorquing. Looking back…I wish I had them take pictures of the area and bolts they torqued so I can share with you all.Has the tightening the bolts helped longterm? I took my car to service center, they tightened the bolts to specs but the noise came back after a few days.
Thank you. I had one appointment, they torqued everything and it was quiet for a couple weeks but then it came back. I am going to a second appointment soon. I keep my fingers crossed.So far the fix has been holding. No issues. It took two service appointments to get fixed. The second one they actually removed the bash/skid plate cleaned debris and retorqued…first appointment was just retorquing. Looking back…I wish I had them take pictures of the area and bolts they torqued so I can share with you all.
Yes the 2 outermost ones on the front edge.NarTaX:
Good find and nice picture, thanks for the post!
Are the 2 outermost bolts the 13 mm of which you speak?
I had the same noise, service center fixed by cleaning and re-torquing.
@NarTaX Could you outline how did you do all of that and what tools are needed for a DYI solution? Would love to do this myself if possible
I took delivery of my MSP 12/22/23 and I don't have this problem, at least not yet. Fingers Crossed I don't.So have any new MSPs in the last year had this problem or has Tesla finally fixed it for good?
As an update (2022 MS), I have visited SC 4 times so far for this issue. The first couple times, the noise went away for a few days. The third time, the noise went away for almost a year. The last time was quite recent so no noise yet. I was told that they put some foam between the bash plate the body of the car to help. Seems like a band-aid solution rather than root-cause fix to me. I expect the noise will come back again. Whenever it happens, I will likely jack up the car myself and try to figure out a better long-term solution. It is quite disappointing so far.Just as an update for those with this issue. The SCs have started adding a rubberized foam to prevent recurrence of this issue. My car is currently in service having this fix applied now.
