Model X was permanently vibrating under acceleration its whole life. If it will get this sort of vibrations as well it will be a double win LOLAnyone know if refreshed model X and MXP owners are also reporting the same vibration issue, or is it, “unique to the Model S, specifically”?
@WilliamG
I might have it. Maybe not. It is not significant enough for me to complain about it or notice it or if it is from the road. I do think someone on here with a LR reported is significantly. I would likely say it is affecting Plaids more due to the acceleration power.Is this vibration only affecting Plaid? Or is long range affected as well?
Only insomuch the Plaid maybe tweaks something in the driveline more easily to cause this issue, I’d guess.I might have it. Maybe not. It is not significant enough for me to complain about it or notice it or if it is from the road. I do think someone on here with a LR reported is significantly. I would likely say it is affecting Plaids more due to the acceleration power.
I wonder in the new X line has this same malady?Only insomuch the Plaid maybe tweaks something in the driveline more easily to cause this issue, I’d guess.
Remains to be seen. Not too many of them in the wild, and as we know this issue tends to not be too noticeable until ~1500 miles or so.I wonder in the new X line has this same malady?
Wouldn’t surprise me. I don’t drive mine hard and haven’t noticed any in 1700 miles. *fingers crossed*Only insomuch the Plaid maybe tweaks something in the driveline more easily to cause this issue, I’d guess.
what about launches? this vibration happens at light throttle, not floored.Someone with a plaid do repeated launches to see if it’s replicable.
To wear down the half shafts. In the name of science of course.what about launches? this vibration happens at light throttle, not floored.
Well, that happens on the drive home after taking delivery.To wear down the half shafts. In the name of science of course.
haha. Ok. Soon as we can get some warmer weather here to get some traction!To wear down the half shafts. In the name of science of course.
It'll get worse with mileage. Mine is really noticable when merging onto the highwayI started noticing a shimmy around 40 after 4k miles. Took the car in and they said they couldn't notice anything. The shimmy is slight so I'll wait to see if it gets worse. They tightened up everything behind the wheel which I think helped slightly. The shimmy is still there but not consistently so I can't tell them how to make it happen. Anyone else hear what it may be? Don't think it's hurting anything but I can't ignore it now I know it's there.
Yes, it will. As asked in the main vibration thread, anyone with the vibration also have Lowering links? Trying to find someone with the vibration that also rides on a lowered car. Do any exist?It'll get worse with mileage. Mine is really noticable when merging onto the highway
@WilliamG “This vibration is a normal characteristic of the Plaid model, spacifically…. No further repairs are recommended” - Telsa Engineering
Instead, ^^^ THIS ^^^ is what you get.
BOHICA!
What did you use to lower your car?So I didn't realize until reading through the thread that this is NOT the same issue that previous generations experienced. The previous issue was related to the angle of cv joints exceeding the design limits which results in bent splines. I had my half shafts replaced 4 times (on 5th set when you include the originals) and I don't have the revised shafts that supposedly fix the problem. The first 3 times the shudder re-appeared within a few thousand miles. The 4th set, which was done at 70K miles (currently at 133K miles) has lasted and the shudder has not returned for me but that's almost certainly because as soon as I got home and before I even tested them at hard acceleration, I lowered the car 1". The problem has never returned.
So nobody with this issue on the Plaid sees an improvement at the lowest suspension setting?
There are no reports yet of the X Plaid doing this.
But lowering the car makes it more uncomfortable…What did you use to lower your car?
I heard n2itive has a good kit that lowers the car as well as fixes the shudder issue.
