Apparently from about the 15 pages of this thread I read, my LR was a unicorn. Smooth as silk at all speeds. My Plaid has the vibration exactly in the 38-42 mph range. I noticed it for the first time yesterday going up a hill.
While I haven't read through all the posts I want to make sure I understand it and maybe help others with a recap.
Possible root cause:
From what I read, it seems like the issue is likely with the front motor. Could be the half shafts, their angle or maybe some synchronicity problem between the front motor and rears. Is this an accurate summation?
Possible solution:
Run a lower ride height if possible? Track mode if with a Plaid with 100% rear bias. Has anyone tried something other than 50/50 or 0/100? Anything else I am missing?
Running with lowering links is not an option where I live. The city of Dallas has some incredible steep approach and departure angle where there are sort of drainage areas along the sides. So when you cross some of these roads, I literally have to crawl across slow enough with the suspension on max height (which limits me to 15 mph anyway) to not slam my nose while crossing.
If I am on the next level down from max height, my nose will be grinding into the ground on a lot of them. So lowering links aren't very viable for me. Not mention some of the highway are such crap, that I've been very close to the nose hitting when on low at 60 mph.
Then with the lower ride height, I then will have an even worse camber issue. We all know where that leads.
