On the comments about a 240volt outlet repaying it's cost thru efficiency gains
How about the convenience of not having to make sure it is plugged in every time you get home?
Get home from work know it is just an hour or two and then have a social engagement or something do you plug in because you know every minute you are home it needs to be plugged in. My car is typically plugged in overnight but during the day if I am coming and going I don't plug it in between trips. Something especially 3 owners are not thinking about yet is plugging and unplugging does create wear. My UMC1 plug to the car is exhibiting wear, runs warm when charging, warmer at 24amps than the wall connector does at much higher charge rate. Long term I think the having to plug in every time you pull in the driveway will cost you a little extra on that end when the UMC end dies, hopefully not taking the car's port with it.
The local superchargers, are they at places you frequent? I have superchargers at a grocery store half an hour away, so if I needed to fall back on that I could at least grocery shop to kill the time, can you say the same?
