A AFN1 Member Sep 5, 2020 15 6 Los Angeles Oct 9, 2020 #1 Oct 9, 2020 #1 I just noticed that I can wiggle my brake pedal from left to right. Does anybody else's brake pedal do this? It doesn't seem to affect braking function, just curious if it is normal or if I should have service take a look at it. Thanks for checking!
L Lounanne Member Aug 25, 2020 173 180 Las Vegas Oct 9, 2020 #2 Oct 9, 2020 #2 Unless I do not understand your issue, I tested and do not have any wiggle.
A artnalex Member May 31, 2020 288 238 Los Angeles Oct 9, 2020 #3 Oct 9, 2020 #3 How much wiggle are you talking about? Like a slight little play either way....or like 1/2” inch play? Mine is fairly solid to-the-touch...with no noticeable play.
A AFN1 Member Sep 5, 2020 15 6 Los Angeles Oct 10, 2020 #4 Oct 10, 2020 #4 Thanks! It is less than 1/2" of play. I did some research and a little bit of wiggle is not uncommon so unless it gets worse I'm not going to worry about it.
D Dblackwood72 Member Sep 12, 2020 7 1 California Oct 10, 2020 #5 Oct 10, 2020 #5 Not sure... I’ve yet to put my foot on the brake
Puma2020 Member Jun 16, 2020 483 760 New Hampshire, USA Oct 11, 2020 #6 Oct 11, 2020 #6 Wait??? We have a brake pedal???
