playing music from USB drive
Discussion in 'Model S: User Interface' started by jlucero, Jul 20, 2015.
  1. jlucero
    jlucero Member
    DALLAS
    how do you do this? i pretty much just added 5 MP3s onto a USB drive, put the drive into the center USB console and trying to locate how to select this on the touchscreen, but dont see any place i can select USB...how do you guys play music through USB?
  2. Soolim
    Soolim Member
    Vancouver, BC, Canada
    On the media app select user devices and you can select USB. The user manual has more detail instruction.
  3. mibaro2
    mibaro2 Member
    Georgetown, ON
    If it doesn't show up at all, then it is probably formatted in NTFS.
    Format it to fat32 and it should work.
  4. smilepak
    smilepak Active Member
    Eastvale, CA
    Anyone got the step on how to export music to FLAC format from iTune?
    I use apple iTune a lot and a lot of my musics are purchased through it. Anyway to export high quality to use via USB?
  5. kuttakamina
    kuttakamina Member
    DC
    You can't go from low quality to high quality. even if you convert MP3 or AAC to FLAC, you will just have bigger files with the same quality.
