Please fix the curb rash risk on Model Y !
Should Tesla fix the curb rash issue ?
  • Yes
    Votes: 63 52.1%
  • No
    Votes: 58 47.9%
  • Total voters
    121
Debating curb rash risk vs. handling/aerodynamics is a fair discussion. My opinion is a small +/-1/4 in tire width ( or rim ) change will not significantly impact handling/aerodynamics. This does bring up the topic of appropriate standard Tires & Rims for the 3 vs. the Y.
Customers that value performance/handling over practicality( low risk ) can choose those performance wheels at purchase. I see lots of complaints from owners with low profile Tires ( Tesla & non-Tesla ) when they hit a pot hole or rough road and end up with flats and bent rims. With the Y positioned as a SUV(ish) there is an expectation that an owner could drive on a dirt road/driveway or survive a city pothole. Making appropriate tires standard on Model Y would make sense.
Seemingly minor changes can very easily have a huge impact on aerodynamics. A 1/4" could be huge (or not). But this will also only impact highway mileage. However, personally, I'd rather have more grip from wider, meatier tires than more range.
Steering response is also impacted by a fatter tire. The steering response with meaty performance tires has always felt great to me, but I've also only switched from stretched non-performance tires to wider, performance tires so I can't compare to a stretched performance tire.
As far as curb rash goes, I rarely visit drive thrus and if I do, I'm super cautious. Never curbed a wheel anywhere else. A little tire protection is nice to have (and I usually do have it since I always swap for wider wheels and tires and/or run the widest tire for that wheel on every sports car I own), but not completely necessary.
Reactions: Lobstahz
I have a model Y on order with 19" sport wheels. I saw a tube video that said the sidewalls on the 19" tires are narrower that the sidewalls on the 18", and consequently the wheels are more subject to damage when you hit a bad pothole. The guy showed where the 19" wheels were damaged and he was replacing them with 18" that have a wider sidewall. Anybody think this is true or is it bogus?
Thanks,
JK
Thanks,
JK
The sidewall is not an issue on the 19" only the 20s.
Reactions: Watts_Up
Thanks,
JK
The outer diameter of the tires is the same regardless of wheel size. So as the wheel gets bigger, the tire sidewall by default gets smaller. The smaller the wheel, the larger the sidewall and therefore the more impact protection.
So, to answer the question above directly. Yes it is true. The larger the wheels, the more likely you are going to have damage to the wheel when you hit an obstacle. This is true of all cars.
Just sharing PSA from other social media site.
Auto Park on Überturbines vs Curb. Ouch!
Showing the wheel bands from AO. Many color options. The only time I hit the curb (rear passenger wheel) the wheel band was damaged and saved the wheel from more severe damage. SO ugly or not (YMMV) I vote for the wheel bands, until the tire size changes.View attachment 429441 View attachment 429442
What kind of rim protectors did you get? Alloygator rim protectors 4 for $750 installed! Seems expensive since online price for Alloygators is $150!! Any alternatives?
Would put black rim protectors on my 20” induction wheels.
