Hey guys,
I was hoping those that know could look over this and see if it seems good and upgradable. If you look at the roof there's space for four more panels which they wouldn't put in as there are pipes there. I want to make sure that if I decide to move those pipes I'll be able to add more panels, probably 4, that the inverter and whatever else will be able to handle it.
The system stats:
9.24kW
7,596kWh 1st year estimated
0 power walls
69% offset [I personally believe it will be more.]
$31,878 before incentives.
$15,354 after incentives and tax credits.
The inverter is the 7600. Is that maxed out? It seems like the 10000 goes for about $500 more. I wonder if I should ask for that one so I can add more panels later. Is there anything else that would prevent it from being upgradable?
Thank you guys I really, really appreciate it!
All the best,
Gene
The system stats:
9.24kW
0 power walls
All the best,
Gene
