Please Please add this feature!!
Discussion in 'Model S' started by Fuma586, Jan 6, 2016.
Tags:
  1. Fuma586
    Fuma586 Member
    Clinton Twp, MI
    So my fusion energi was able to preheat itself on a schedule so long as the vehicle is plugged in. It was one of the best features of the car. Every morning I would get in it at 6:30 am and it would be toasty warm even inside my unheated garage.
    Today I became a proud owner of a S85 and realized that it was the only thing missing from this amazing machine.
    I feel like this is an easy enough feature to add with a software update. It may even be a competitive advantage to 3rd party mobile app ;-) looking at you Remote S.
    And or, an algorithm that begins your overnight charge so that it commences when your ready to leave, this way you battery is warm enough to accept regen on those cold winter days and no energy is wasted on a heating element.
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Tesla has a feature called "Smart Preconditioning" that is *supposed* to do this automatically by figuring out when you normally get into your car and preconditioning it for you. That said, most people have it turned off because it's not particularly smart. I haven't used it in many releases so it might have gotten better. It takes some time to "learn" your behavior and is supposed to do things automatically after that point. You can give it a shot and see if it helps. Worst case you just turn it back off. Would be nice if they just had a manual option like you requested.
    The other option is to use VisibleTesla on a PC and have it turn on the HVAC on a schedule.
  3. JenniferQ
    JenniferQ Supporting Member
    San Diego, CA
    We can do this from the Remote apps, just not on a schedule. That should certainly be easy to add.
    I don't personally like how the car is supposed to figure out my schedule because I don't really have a regular schedule so it heats itself at weird times thinking it's figured me out, but I'm not that scheduled.
  4. Fuma586
    Fuma586 Member
    Clinton Twp, MI
    So it does exist! Thanks for the info!
  5. msnow
    msnow Active Member
    SoCal
    I think you need to set a home and work location as well as enabling calendar sync. I believe if it sees you are leaving for work at a certain time it will precondition. Check the manual.
  6. andrewket
    andrewket Well-Known Member
    Tesla tried to be too smart. A simple pick a time and day(s) would be more useful, imho.
  7. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    Yes, but hardly worth it IMO. The car heats up in just a few minutes. Maybe if you jump in at precisely the same time every day, it could be useful. It also does not need to be plugged in to pre-heat. It will heat up in the mall or office parking lot just as quickly.
  8. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    I definitely do think they should allow manual pre-heating of the car on a fixed schedule, and I'd also like independent battery heating. I don't like it tied to cabin heating which I believe it is (when pre-heating).
    I'm too OCD for the "smart" preconditioning.
    During these winter months I haven't been able to experience one-pedal driving since my commute is only 15-20min and the battery isn't warm enough for full re-gen.
    Ah, the joys of first world problems.
  9. Fuma586
    Fuma586 Member
    Clinton Twp, MI
    @andrewket
    Agreed. I manual program my "smart" thermostat. Maybe that makes me a control freak but it should at least be an option.
  10. green1
    green1 Active Member
    Calgary, Alberta, Canada
    "Smart preconditioning" was about the dumbest possible way Tesla could have implemented that feature. it IS on a schedule, it's just not one you have any control over at all. If you have a "regular" schedule, it just might happen to guess it right, but it requires you to be leaving at the same time each day, so that would have been just as easy for you to set based on a clock instead of the Tesla guess, and if you don't have a "regular" schedule, it's completely useless.
    They SHOULD have implemented it 2 ways:
    1) allow you to select a time to start it, and which days of the week to do so.
    OR (at the owner's choice)
    2) work based on calendar appointments.
    For anyone who can get smart pre-conditioning to work, number 1 would also work perfectly, and without the guesswork. For people like myself who have odd schedules, number 2 would be perfect as everywhere I go is in my calendar (including my work shifts)
    Unfortunately whoever wrote the "smart preconditioning" did it in a way that was anything but smart.
  11. pgiralt
    Cary, NC
    I've got a fairly regular schedule and it never seemed to work well for me last time I tried it.
  12. Knobby
    Knobby Member
    Ottawa, ON Canada
    Yes I'd love it if that would work. The remote access never freakin works when I want it to. In fact for the last week the car won't respond at all. And I do have the car on "always connected' and also on "don't save energy" because as the app so helpfully advises... you need to do that if you want faster response. I'd just like ANY response at this point. Seriously, remote access is at best flaky and usually broken. And don't get me going on this 1/2 hour to re-register on 3G BS after sleeping.. It usually gets connected just in time for me to pull into work. Niiiice.
  13. green1
    Welcome to Canada... Canadians have been complaining about the 3G here ever since Tesla launched... Unfortunately the LTE isn't getting any better reviews.
  14. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    If you have found "Remote S" cannot connect but the Tesla app can, log out of Remote S, (tap the left hand top icon to show the drop-down menus and then tap the icon on the right that is a car with arrows surrounding it. This will reveal a box with the Settings - Sign Out and Done. Tap Sign Out. Close the app and relaunch it and sign in with your Tesla ID and it should re-connect.
  15. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    It worked perfectly for me for about a month and then simply quit working. It was great while it worked:wink:
    Update:...Oh, and I just walked out to make sure that I wasn't crazy and that it was on. It is...still learning.
    Oy.
  16. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    Not sure if the current way things work supports your option 2 (calendar-based). The car actually doesn't know your calendar appointments when your phone is not paired to the car. It's only after pairing does the Tesla App transfer the calendar events over to the car. It's the most straightforward way to support multiple drivers with independent calendars. Of course, it could be implemented on the phone app side... The app itself can send the pre-conditioning commands to the car based on it's schedule. I think that would solve all of the problems.
  17. Max*
    Max* Charging
    NoVa
    Tesla should have went the Nest way. It "learns" my schedule, but I can see what it learned, and if I don't like it, I can fine tune it.
    Tesla decided to just implement the first part... go figure.
  18. tstafford
    tstafford Supporting Member
    Nashville, TN
    What you are asking for can be done in Visible Tesla I believe.
  19. Caligula
    Caligula Member
    San Diego
    What's this about an invisible Tesla?
  20. Fuma586
    Fuma586 Member
    Clinton Twp, MI
    I have installed Visible Tesla, and it is very useful. But for this application it is not practical. It requires that your computer be on and Visible Tesla open and running at the time that you want your car to preheat or charge. For people who are on the go and use a laptop this just becomes more of a hassle than opening the app on your phone and pressing the button and possibly a reminder so you dont forget.
    - - - Updated - - -
    Software update IS imminent. I have my fingers crossed for it to be fully implemented like this. Super easy for them to do.
