I clicked “disagree” in support of your post.If someone is in disagreement they should be required to post the reason and NOT just hit a button. I disagree with the Disagree Button.
I have never used it except when someone uses it on me first. I then hit them 3 to 1 because they should post their reason and not hide behind a cheap "hate" type button.For someone that doesn't want the disagree button you sure use it a lot without posting a reason.
Can't we agree to disagree? (see what I did there)
Because I hit "Disagree" and you seem to need a response, so: I did it because that's one of the stupidest things I've ever read here.I have never used it except when someone uses it on me first. I then hit them 3 to 1 because they should post their reason and not hide behind a cheap "hate" type button.
This is troll behavior and can result in a suspension or a ban. Please stop it. There is no reason to retaliate just because someone "disagrees" with you, whether they post a reason or not.I have never used it except when someone uses it on me first. I then hit them 3 to 1 because they should post their reason and not hide behind a cheap "hate" type button.
PS: This was meant in good humor, if it wasn't obvious (and it might not have been). Some smileys to counterbalance things:Because I hit "Disagree" and you seem to need a response, so: I did it because that's one of the stupidest things I've ever read here.
Normally I wouldn't post such negativity or something so "attack-oriented", but you did request it, so there you go.
I've gone back and asked (usually in PMs) why I've had dislikes before. Once was a mistake. Every other time it was actually valid and edifying. Mostly I just go "huh" and move on.
