Please sign the petition to enable Spotify in U.S. Teslas
Discussion in 'Model S' started by pakman, Oct 8, 2016.
  1. pakman
    pakman Member
    New York
  2. msnow
    msnow Active Member
    SoCal
    I'm pretty sure the Slacker contract has something to do with Tesla waiting a couple more months before enabling Spotify perhaps on 8.1. I don't think a petition is necessary.
  3. pakman
    pakman Member
    New York
    The issue is one of cost. The commercial terms of Spotify are more expensive to Tesla than Slacker, since Slacker is a more limited service and operates with less expensive licenses. The simple solution is to enable it for those of us with existing Spotify accounts so Tesla doesn't have to absorb additional cost.
    If enough of us suggest it, they will enable it...
  4. msnow
    msnow Active Member
    SoCal
    I'm saying they plan to anyway.
  5. cwave1
    cwave1 Member
    Mississauga, ON, CANADA
    If you change the petition to North American cars (to also include Canada), then I'll sign it.
  6. pakman
    pakman Member
    New York
    Hi @cwave1,
    Changed it! Thanks,
    David
  7. Tam
    Tam Active Member
    Visalia, CA
    Thanks for starting the petition!
  8. odguy
    odguy Member
    Wisconsin
    Not trying to derail this thread, but if I signed up for slacker premium would I be able to repeat a song by tapping the back button?
  9. deonb
    deonb Supporting Member
    Redmond, WA
    Not signing this. Tesla Engineering needs to take a step back and prove they can add new features without breaking old ones.
    Start small - move the battery icon one pixel to the right - only thing in the update. Does Hill Hold still work?
    Great... next time try to move 2 icons...
    8.0 has turned my Slacker into a White Elephant. It now stops Slacker each time I park in a place without cellular reception (like at my Office), and instead it always switches to the AM station that resonates with engine noise.
    I used to use Slacker all the time but it's unusable like this, so I just turned off the Radio. Even if you change it from Slacker to Spotify, without fixing basic stuff like this, it won't help.
  10. msnow
    msnow Active Member
    SoCal
    Spotify isn't really a new feature. It's been running in Europe for quite a while.
  11. Tam
    Tam Active Member
    Visalia, CA
    I respect your principle to fix an existing broken one first before getting a replacement.
    However, if there is a choice of fixing an existing broken Slacker that even in its perfection, it's still inferior to Spotify, then I would not bother to fix the broken inferior Slacker in the first place.
  12. doctorwho
    doctorwho Member
    Eurobin, Victoria. Australia
    I'd modify the petition to add something along the lines of adding a debugged full feature set Spotify to US cars. My car Spotify regularly loses all it's playlists apart from the ones displaying on the screen at that time, it freezes when there's 24 seconds remaining of a song anytime I have less than perfect full strength reception. It gets stuck in a loop repeating the same fragment of song over and over that can only be fixed with a centre screen reset.
    This is a well known fault and it can be fixed with a factory reset that wipes the corrupted preference file along with every other setting in the car. After doing this several times, resetting all my preferences is more annoying than putting up with Spotify
  13. msnow
    msnow Active Member
    SoCal
    Well if ever there was a reason for not wanting Spotify you just gave it.
  14. Tam
    Tam Active Member
    Visalia, CA
    We then have a choice between an inferior and buggy Slacker or a superior but also buggy Spotify.
    Either way, it's still a buggy world!
  15. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Why is Spotify better than Slacker?
  16. Tam
    Tam Active Member
    Visalia, CA
    Maximum sound quality for Slacker is 128kbps while it's 320kps for Spotify.
    Spotify has a larger library and serves globally while Slacker is like a local library serving regionally in US and Canada.
    Tesla Slacker version is not an actual premium version. Sometimes, when you call up a song and it plays you a similar song, not the one that you asked for.
    It is even worse if you ask for a Vietnamese song, Slacker would give you a completely unrelated song in another tongue! Spotify has no such language problem.
    With Spotify at least you have a "playlist" to be lost, you have none with Tesla Slacker....
  17. doctorwho
    doctorwho Member
    You can also use your own Premium account (if you have one) with Spotify and so have multiple playlists. It also means that you can use Spotify on your phone as a 'remote control' to control music in the car so that passengers in the back seat for instance can select music.
  18. hingisfan
    Kingston, Ontario
    Are you sure about the 128kbps limit on Slacker? I changed it to 320 on my phone app and I think the car picked up the setting, as its buffering more slowly now.
  19. Tam
    Tam Active Member
    Visalia, CA
    I am sorry that I am behind the time. I looked that up and Indeed Slacker has upgraded its speed to:
    64, 128 and 320 kps since 2015 as mentioned in:
    Slacker Radio (US) Streaming - 320 Kbps Bitrate Support
    In previous firmware versions, you were able to set Tesla Slacker sound quality to either Medium or Best which was pointed out by the above post as 64 and 128 kps.
    With this current version, there is no longer adjustable Tesla Slacker sound quality control.
  20. cwave1
    cwave1 Member
    Signed. Thanks for changing it to include Canada.
