Plug Adapter on my Universal Mobile Connector has melted...
Lyon
2016 S P100DL, 2016 X P90D
2,005
216
Eugene, Oregon
Mine got melts tonight, too. My day's did about a week ago. His UMC actually stopped charging and showed a red light, fortunately I just happened to touch mine tonigh and found it to be too warm to touch for more than a moment.
I got made fun of on another thread for buying a second UMC as a back-up. I gotta say, I'm feeling a little smug at the moment. :wink:
In my case, hard to say. It had been charging for perhaps a couple of hours last night when I thought to check it after seeing this thread. But I haven't had the 14-50 adapter off of the connector since I took delivery back in February. My guess is that the melting has been an ongoing process, rather than an instantaneous event.
Dave EV
2,462
3,205
Earth
Looks like there might be some sort of pin alignment issue contributing to the issue?
Too bad the pins on the adapters aren't as tough as the ones on the car.
144F is HOT especially considering that you're measuring the outside of the connector - the pins must be at least 20-30F hotter.
Personally I wouldn't charge at more than 20-30A or so until Tesla figures this one out and periodically check temperatures after 30 minutes of charging.
The real issue is that if you're using a timer, you might never notice the plug overheating until it melts, especially if you leave your UMC plugged in to the wall.
Is everyone who's had an adapter melt letting the "brick" hang from the plug as Lightning Jeff is in his pic? That puts a lot of strain on the connector - you can see that Lightning Jeff's adapter doesn't appear to be fully seated.
In the pics on this thread I also notice that the bottom of the power pins is the primary melt point - this reinforces the above theory that there is too much strain on the adapter.
It's actually the connector pins, so if this is a flaw, it may be a more expensive one to fix. And yes, they seem tiny for the amount of current they're moving.
I'll be interested in what others do, as this always seemed a little off to me - to the point that I've thought about mounting a bracket for the "brick" to sit in and relieve that strain. That said, I actually don't think the strain is that great. I'm not sure that gap you see really is one - or that, given how tight the two pieces fit together, it contributes to any actual misalignment of the pins. But, you may be onto something.
Ingineer
Electrical Engineer
Aug 8, 2012
1,512
3,724
I recently opened one of the UMC's up, but it's a pretty destructive process due to the housing overmold and it being glued shut. It's a "one-way" trip, so definitely do NOT try this at home!
Tesla is really pushing the limits on the UMC design! When used with a 50A adapter, It's putting out a 66.7% Duty cycle, which equates to 40A. They use paired 2.5mm wires for each side of the line, (Equivalent to ~#13AWG) and inside the box they use the same P&B relay ClipperCreek uses on the LCS-25, a single 30A rated relay. (at 40A!) Now since it's almost never going to be expected to interrupt any sizable current, this is probably fine as long as the contact system in the relay is low enough resistance and there isn't too much heat dissipated. I haven't done any thermography yet.
It's arguable that splitting the high-current between 2 smaller conductors is better for heat-dissipation, but then you sometimes have pesky termination issues. Inside the UMC, Tesla welds the 2 conductors to a little square terminal, then screws this to a PCB terminal. So this is a good termination and it looked well-done by my assessment. Having 4 smaller wires instead of 2 larger ones definitely makes for a smaller, more flexible cable overall, so regardless of any potential current handling gain, it's good ergonomically.
I definitely don't like their interchangeable right-angle plug connector design. First off, if you are going to do right-angle, why not make it symmetrical? That way you could flip it 180 degrees if your outlet is installed upside-down. (Patent-Pending! =)
Their "dongle" design makes for elegant and simple plug adapters, but it ends up being a really big blob, especially when used on smaller outlets (NEMA 5-15). This will put even more stress on the outlet, with the high bending moment due to hanging the weight of the UMC and cabling off a long adapter conflagration. I think I prefer having a short length of cable for each adapter, as this makes the final plug smaller, more compact, more flexible, and spreads out heat. This is the design choice I made on the EVSE upgrade. I use a NEMA L6-20 (L6-30 on higher-power units) as my intermediary adapter connector, which is a good design, positively locks, and still very compact. Then I use a short cable to connect the adapters to the plug, and all connections are welded and fully overmolded. This maintains flexibility, reduces physical stress on the outlets, and spreads out any heat generated. It also means you don't need an adapter at all to "go native". I decided against right-angle choices on most adapters because there is no standard for outlet installation in the wild, and you could very often end up with a 180 degree wire exit, which is not a good idea.
-Phil
Doug_G
Lead Moderator
Global Moderator
Apr 2, 2010
17,888
3,416
Ottawa, Canada
The contacts on the T92S7D12-24 relay has "Rated current" of 30A, but if you look at it in more detail they have a "limiting continuous current" of 40A.
The datasheet specifies how many operation cycles you can do at what current. At 40A/277VAC they are rated for 6000 cycles. Mind you, it is likely that Tesla is only operating the relay with the power off, since the car has much larger contactors. (Except they probably pull power immediately if a ground fault is detected - but you can do that 6000 times.)
So it does look like they are respecting the limits of the part... but yes, this isn't a conservative design!
Did anyone notice if the power cable felt hot before the plugs melted? I noticed yesterday that my cable was very warm. Also, the unit with the green lights that show if it is charging properly is on backwards (it faces the wall when it's hanging). Now I'm a little worried it might not be wired properly. I'm going to get a bracket to put that unit on so it is not just hanging and I can keep an eye on the lights.
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,030
1,030
Yes, it does, because the heat is carried through the wires, but there will clearly be a hot spot. In my case it was the connection between the UMC adapter head and the adapter itself. In one case on this forum, it's clear that it was a faulty receptacle rather than the adapter because the hot spot was at the 14-50 blades.
PhilBa
1,382
70
Seattle
My new garage is getting wired right now so I am keenly interested in this topic. Several things to consider:
  • With that much current, contact area is a key issue. I'm pretty sure the spec assumes full contact along the entire pin/receptical. Any less contact area means higher current per unit of contact area and thus higher heat.
  • It looks like all the heat problems occur with the 14-50 connectors and not the screw terminals on the 14-50. Given that the early UMCs are getting replaced by Tesla, that says they are assuming insufficient contact area.
  • 14-50s in general weren't designed for a lot of insert/remove cycles. How many times would a dryer be plugged/unplugged? Care in inserting and removing is important. Try to be perfectly straight. It looks like the lower pins are where the problems occur. The right angle plug probably encourages putting upward torque on the plug when removing it, thus causing wear on the lower pins.
  • Dialing down the current mitigates the problem because it drops the amount of current flowing through the diminished contact area thus reducing the heat.
  • Making sure the 14-50 is very securely installed is important. No flex. Metal boxes (no plastic), securely mounted to a stud, everything really tightened down. A good electrician should do this but they sometimes cut corners.
  • Make sure that your UMC doesn't place stress on the outlet. Over time, movement could cause wear and reduce the contact area.
  • Something I don't know but will ask my electrician (who seems pretty good) - are there different grades of 14-50s? I see ads for industrial grade 14-50s. This is one area I won't skimp on.
FlasherZ
Jun 21, 2012
7,030
1,030
[*]Something I don't know but will ask my electrician (who seems pretty good) - are there different grades of 14-50s? I see ads for industrial grade 14-50s. This is one area I won't skimp on.
Different manufacturers test for different cycles. There isn't a standard, per se, for industrial vs. recreational grade, etc., but some may be built to be tougher (for example, 14-50's are used for RV's, so RV parks will experience a good number of cycles).
Most of the failures we're seeing are not related to the 14-50 blades, but rather the pin surface area between the adapter and the UMC's plug-head.
jerry33
20,833
29,909
Texas
A 14-50 is an RV plug, not a dryer plug (dryers use 30 amp circuits, not 50 amp). RVs are plugged in frequently. (Not saying that you're incorrect about the 14-50 not being good for that many cycles though--that seems to be normal even though RV plugs tend to be unplugged frequently)
So I caught my car still charging when I left for work this morning. It had been charging for about 4.5 hours on my 14-50 outlet. The charging cable was quite warm, but the connector going into the outlet was HOT. I really can't guess what the temperature was, but I was only able to touch it for about 3 seconds before having to remove my finger due to the pain from the heat. Yeah, I know, not very scientific. Maybe I have a low pain tolerance! :)
In any case, is that level of heat normal? Are you all able to to comfortably touch your connector after a few hours of charging? I have to admit it made me quite nervous. I don't know how hot things need to get to catch fire, but I am not used to my electronics getting that hot, and I'm wondering if I'm too sensitive or if I potentially have a bad adapter too.
your thoughts?
jerry33
20,833
29,909
Texas
No.
Yes. I just had my UMC replaced today for being hot (Called service before it actually melted.) What I felt was:
Panel breaker slightly warm (normal)
14-50 receptacle cool (normal)
14-50 adapter warm (normal)
UMC adapter end hot
Cable between UMC adapter end and GFI hot
GFI hot
Cable between GFI and charge port connector cool (normal)
Charge port connector cool (normal)
This was after about thirty minutes charging at 33 amps. I suspect it would have melted had I not stopped charging to let it cool down (there were 31 miles of range left when charging started)
