Plugging in an iPhone
Discussion in 'Model S: Interior & Exterior' started by Patrick W, Dec 3, 2016.
  1. Patrick W
    Patrick W Active Member
    SLC, UT
    I recently traded in the S I bought last year for one to be delivered in a few weeks (traded it so I could get v2 hardware and continue with unlimited supercharging).
    A few days ago I stopped by the local Tesla store and saw the current Ss include a center console which includes a place to plug in an iPhone. But when I tried that with my phone the phone's protective case prevented the car's connector from getting far enough into the phone to make a connection.
    That case has saved the phone more times than I can count (poor phone gets dropped a lot) so it needs to stay meaning if I have to I'll continue to charge using the 12 volt receptacle.
    But, per chance has anyone come up with a way to charge using the Tesla plug while the phone is in a protective case?
  2. tagpats
    tagpats Member
    Falls Church, VA
    If you search "dock extender for iPhone" on Amazon you will find many options to give you the clearance you need to charge your phone in the case. If you search, there is also a post on this forum that provides a step-by-step guide with pictures to modify the wiring harness with a toothpick. My harness was slightly different than the one using this approach so it would not work for me.
    The only downside to the extender is that over time it can become loose enough that you will need to hold it in place when you remove your phone or it will come out still connected to the end of your phone and you'll need to reattach it. Not a big deal, but could be irritating to some.
  3. ahm
    ahm Member
    When I need to charge in the car I take my phone out of the case. I know it's not ideal, but it works.
  4. mblakele
    mblakele pre-jackpot member
    SF Bay Area
    Don't you still have direct access to the USB ports? I have the yacht floor and I keep a USB-lightning cable in the car permanently, attached to one USB port. I wouldn't want a console dock anyway, because I want to have Waze running closer to eye level.
  5. tagpats
    tagpats Member
    Falls Church, VA
    Yes, there is a free USB, but if you want to avoid a cable the dock is a cleaner, if less functional way to charge. When we can mirror Waze, Google or Apple maps to our big boy screen, all these problems go away.
  6. mblakele
    SF Bay Area
    We're getting off topic, but I'm not so sure I'd mirror Waze to the big screen even if I could. As it is my phone is closer to eye level and road view than the big screen is. Maybe things will look different in a TM3 with its screen placement, plus AP2.
  7. f-stop
    f-stop Active Member
    Vancouver BC, Canada
    @Patrick W you should be able to make a very simple mod to the connector in your console to make it fit your iPhone with case, see: Modifying the Tesla Center Console for phones in cases (Pictures Included)
    the thread originally discusses the older style console, but later posts show a similar mod with the newer console in refreshed Model S.
    • Helpful x 3
  8. Patrick W
    SLC, UT
    Yes, 2 USP and one 12 volt. But all of those require cables and I'd like to get away from that.
    the car won't arrive for another couple of weeks so I'm going to wait until it gets here before deciding what to do.
    Thanks.
  9. Patrick W
    SLC, UT
    Thanks, but my modification skills are less than stellar. :) I'm afraid I'd just make the situation worse.
  10. NewJerseyMS
    NewJerseyMS Member
    New Jersey
    This.
  11. f-stop
    actually the mod is really simple, screwdriver and Xacto knife are the only tools required. Basically the mod simply pushes the connector a few mm further out of the hole in the dock.
    Once you get the car, you can always just remove the 2 screws holding the dock to quickly inspect what's going on and decide if you want to attempt. take a look at the photos in post #38 of the thread I mentioned for a look at the newer console's dock.
  12. HebrHmr
    HebrHmr Member
    Florida
    I use a Lifeproof and they aren't designed to be removed constantly. If you misshape the case too much it loses its waterproofing capabilities.
    I imagine I'll run into the same problem when my car shows up and need an extender.
  13. Altes
    Altes Member
    SF Bay area
    Check your plug install. There are two settings for the piece that holds the lightning plug. Works great on my thick case but was not installed that way
  14. NikeWings
    NikeWings Active Member
  15. Patrick W
    SLC, UT
    Sorry but not sure what you mean. Are you saying that the height (the the distance the plug extends from the base) is adjustable?
  16. Altes
    Altes Member
    SF Bay area
    Yes, take it apart (its a pain) and there should be an L shaped tab that screws down on the lighting connector. One is thicker and pushes the connector further up into the dock. YMMV as I have a brand new MS
  17. Drone Flyer
    Drone Flyer Active Member
    Canada
    The car comes with adapters to hold the phone with case in holder.
  18. HebrHmr
    HebrHmr Member
    Florida
    Now that you mention it. When I showed my OA my phone she said that they'd just have the service guys "set it up" for my phone. I guess what you're explaining is what she meant.
  19. Altes
    Altes Member
    SF Bay area
    Yep. They "set mine up" too. Worked fine on way home but then stopped. Took it apart and discovered the trick. They set it up for you because it's a giant pain to do
  20. Patrick W
    SLC, UT
    What is an "OA"? I'm guessing it's a Tesla employee of some sort but there are so many different job titles I don't know them all. :)
