Plugging in every day
Discussion in 'Model X: Battery & Charging' started by Ranger29, Oct 26, 2020.
  1. StanT
    StanT Member
    Fishkill
    Just FYI- this discussion just made me think about other ways to open your charge port- like talking to Siri, etc. So...
    I believe the app Tesla Commands can create siri shortcuts to do all sorts of things including operations around the charge port. This includes adding shortcuts to the new home page. Not sure this helps (or if you have an IOS device)- but here it is:
    ‎Commands for Tesla
    Also in theory you can create your own shortcuts using the Tesla app APIs- I really haven't looked into any of this but I know it existed- so here it is:
    Apple Siri commands and Apple shortcuts for your Tesla
  2. Ranger29
    Ranger29 Member
    Madeira Beach, FL
    Thanks!
    Ranger
  3. Soey22
    Soey22 Member
    Fort Erie, ON, Canada
    The battery is most happy at 50% this will always be the sweet spot when not driving the car for long periods or only short trips. I always plan my trips and charge up accordingly, but if I’m driving local ill always keep battery at 50 and always plugged in. I have a V3 charger less than a mile and a free L2 48 amps .5 miles away. I almost never super charge even with my FUSC. My battery degradation is less than 1% after 15k miles, also never charged to 100%, never higher than 90%
  4. ElectricTD
    ElectricTD Member
    Illinois
    I have just purchased a 2021 X. I am finding that I only drive about 20 to 30 miles a day so the discharge is minimal. I do plug in when not using but where did you find that 50% is the best place to charge to when you don't drive long distances?
  5. TigerTan
    TigerTan Member
    Orange County
    I had my 12V replaced last week and received conflicting advice / direction from my SA (somewhat tenured 6 yrs). He said that the “engineering team” has had learning about battery care (main pack of course and not the 12V), with that said I’m not sure why Tesla doesn’t update the manual of this is true. Similar to what others mentioned, charging from a lower state (30%) to 80-90% is what he recommended. In addition, he mentioned NOT to keep it plugged in and to only plug in to charge. The only time he said to leave it plugged is if you leave for extended periods (ie 30 days). In case you’re wondering, the 12V life on the model X is about 2 years from what he’s seen regardless to what you do. I’ve read similar statements in the forum. Just thought i’d share, but am interested in some of your thoughts on his comments.
  6. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    All studies that have been done on lithium ion batteries.
  7. Arctic_White
    Arctic_White Member
    Edmonton, AB
    This is exactly what I've heard from multiple other sources as well: charge from 30% up to 90% if possible.
    Also: don't leave it plugged in unless storing the vehicle for more than 1 week. I'd definitely plug it in but leave the SOC at ~50% if I'm not driving the car for an extended period of time.
  8. TSammy
    TSammy Member
    Georgetown
  9. TSammy
    TSammy Member
    Georgetown
    I plug in every trday if the sun shines.
    It is cheaper to use my excess solar to charge than sell it to the electric company(GUS does not refund Power Cost penalties on buybacks).
    My X60D is 4&1/2 years old with 50k miles and still shows 190 miles.
    I do not understand why you would buy a Model X, pay the sales tax, and insurance premium and then NOT spend $500 for a proper charger.
    • Disagree x 1
  10. jboy210
    jboy210 Supporting Member
    Northern California
    Many EV drivers own multiple EVs from multiple companies. J1772 plug works across almost all brands. And those that do not work directly, like Tesla, provide an adapter.
  11. Rocky_H
    Boise, ID
    This makes no sense at all. What is it that you think would be "proper"? This person is using a wall mounted, 240V, electric car charging station. That is about as "proper" as it gets. What do you think this person should waste $500 for that would be more "proper"?
  12. Johnszal
    Johnszal Member
    fl
    What I find is that keeping it plugged in masks the problems with vampire drain , etc. Severe problems are noticeable when not constantly being masked by being charged whenever parked.
  13. Camelroel
    Camelroel Member
    Lelystad
    I have my start charging set at 23:00 hrs. And I still can see vampire drain as I will not even start charging every day if not used. 3% drop in SOC is no enough to have him start charging again.
    I didn't test what is does when you don't give a start time but I assume the same.
  14. mk677
    mk677 Member
    jacksonville fl
    according to the gospel as interpreted by the prophet Elon, a plugged in tesla is a happy tesla.
