For those wondering about service cost any, just has mine done for the first time in 2 years (car is 2 years old now). I skipped the 1 year service since it was already in the SC a lot for fixes at times and it doesn't get driven much.
Note:
The below included 2nd year service items + 1 year service AWD front & rear drive unit fluid flushes (that is usually in 1st year and 4th, etc.) + also a break cleaning service that they recommend in cold climates only so can subtract $150 from total if not somewhere snowy/salty/cold.
2016
Model X
Blue Metallic Paint
Concern: Install 12V Battery Plug
Corrections: Install 12V Battery Plug
Technician installed 12V battery plug per service bulletin.
$0
Concern: Customer states: Perform second year annual service.
Corrections: Fixed Price Annual Service 2 Year/25000 Mile/40000 km Technician performed 2nd year annual service.
Total Labor & Miscellaneous Items: 825.00Pay Type: Customer Pay
825.00
Concern: Additional Items for Annual Service (Included)
Corrections: 2 Year/25000 Mile/40000 km Service
- Pulled logs and checked for active faults: No active faults .
- Checked firmware version: Staged latest version
- Performed function check of closures (moving glass, doors, trunks): Cleaned and lubricated latches. Good, no issue.
- Tested and inspected customers charge system with shop cable: Good, no issue. Vehicle charged normally at correct amperage.
- Replaced:
- Wiper Blades
- Key Fob Battery
- Carbon Filter
- Remote Keyless Entry: Good, no issue
- Seat belts and latches: Good, no issue
- Interior/exterior lighting and horn: Good, no issue
- Performed inspection of powertrain and chassis components: Good, no issues.
- Checked fluid levels: Topped off washer fluid. Brake and coolant levels optimal. No signs of leakage.
- Inspected tires and rotated as necessary.
- Measured tire tread depth at:
(Outer) LF: 6/32 RF: 6/32
LR: 7/32
RR: 7/32
- Adjusted tire pressures to B-pillar spec: 45psi Front, 45psi Rear
- Measured brake pad thickness (mm)
LF: 8mm RF: 8mm LR: 8mm RR: 8mm Park: 5mm
- Performed 4-wheel alignment
- Test drive: Vehicle functions as designed.
- Cleaned and lubricated panoramic roof assembly (Odd, copy/past since this is a Model X) ;-)
- Performed Air Conditioning service and replaced desiccant cartridge - Performed brake fluid flush
Parts Replaced or Added
Part Quantity
WIPER BLADE, DRVR, LHD, MDLX 1(1034389-00-B)
WIPER BLADE, PASSENGER, LHD, MDL X 1(1034390-00-B)
Carbon Filter - Model X (1039042-00-B) 1
BRAKE FLUID DOW SERVICE 1 QT 2(1060099-00-A)
Pay Type: Service Plan
Concern: Brake Service Approved
Corrections: Brake Caliper Pad Slides and Parking Brake Calipers - Cleaning and Lubrication (With Wheels Removed)
Technician performed brake maintenance. Cleaned and lubricated brake caliper pad slides and parking brake calipers. Verified proper brake operation.
$150.00
Concern: Customer states: Check rubber seals around FWD as they do dangle loose in some areas, but no issues yet.
Corrections: Seals Body Closures General Diagnosis
Technician inspected falcon wing door seals, verified customer concern. Technician identified seals were coming apart, technician removed and replaced falcon wing door bottom rear garnish seals.
Corrections: Cladding - Door - Rear - Wheel Arch - LH Technician removed and replaced left rear wheel arch.
DOOR CLADDING ASY - RR WHEEL ARCH, 1 LH (1045890-00-E)
TETHER CLIP,4.8x15 HOLE,6.5x15 BODY 4(1062986-00-A)
Corrections: Cladding - Door - Rear - Wheel Arch - RH Technician removed and replaced right rear wheel arch.
Pay Type: Warranty $0
Concern: Customer: first year annual service was not performed. Please perform both front and rear drive unit flushes that were not performed.
Corrections: Rear Gearbox Fluid - Small Drive Unit
Technicians performed 2nd year annual service w/ alignment. Performed front and rear drive unit flushes.
Parts Replaced or Added Part
212-B ATF (1031106-00-A)
Corrections: Front Gearbox Fluid
Quantity Unit Price
1 $20.00
Quantity Unit Price
1 $20.00
Total Job Parts: 40.00
Total Labor & Miscellaneous Items: 337.50Pay Type: Customer Pay
$377.50
$1,312.50
Total Parts
$40.00
Subtotal
$1,352.50
Sales Tax
$4.10
TOTAL AMOUNT
$1,356.60
Note:
2016
Model X
Blue Metallic Paint
$0
825.00
- Replaced:
- Wiper Blades
- Key Fob Battery
- Carbon Filter
LR: 7/32
RR: 7/32
Part Quantity
$150.00
Quantity Unit Price
1 $20.00
Quantity Unit Price
1 $20.00
$377.50
$1,312.50
Total Parts
$40.00
Subtotal
$1,352.50
Sales Tax
$4.10
TOTAL AMOUNT
$1,356.60
