croman
I agree with your point, but in planning a long cross-country trip, there were several places where I can "cut a corner" due to Supercharger placement, where I would have been leery to do so with the 60kWh battery.
For example, going from Amarillo TX to Trinidad, Colorado looks like this with the MS60D:
And like this in the MS75D:
There are places on regular long routes, like this, that make it worthwhile.
Be careful when using EVTP to compare routing differences between the 60 and 75 kWh batteries to always click the "Route thru Superchargers" button between changing battery sizes. It may route totally differently with the larger battery, but just changing the battery size selection just takes you on the same route that was plotted for the smaller battery -- you have to hit the button to get it to re-route.
I know you were using ABRP, but similar situations arise in making those comparisons using whatever tool. Look for places where you have to take the long way around with the 60 kWh battery due to Supercharger placement.
This is why evtripplanner is bad. In your example the direct route uses less than 60kwh of energy. A 60 could do it just like the 75. Not to say examples don't exist but that isn't the most compelling. I skipped the Cleveland supercharger because I upgraded and couldn't have made it to Maumee OH on my return trip. Evtripplanner said my 60D couldn't make it from Erie PA supercharger to Ithaca NY. 59kwh trip. Made it with 9 rated miles. Sometimes my margin of error was far more aggressive but a 75D does make it a lot less stressful.
