The EPA docs show that the Model 3 is handled just like the Model S.
No they don't- there's physically different parts in the P drive units for the S (you noted this yourself- the inverters are different), not so the 3 (where the inverters are all SiC, and are part of the drive unit). And no lot sorting on the S either, since they're not the same parts.
I suppose the rear motor could be software limited on the AWD, but it could be a different one.
But why WOULD it be?
Software limiting is free. A different physical part is a lot of cost and complexity for literally the same result.
The rear motor in the RWD has been produced with no issues for a year now, and is the same one going in the P too. Why in the world would it make
any sense to create a "new" rear motor JUST for the AWD that only has like 10% less output- instead of just software limiting output by 10?
I mean- we kinda do- but people seem awfully desperate to deny it.
But I guarantee it has a different part number, so from a manufacturing stand point it doesn't make much difference.
Of course it does. Drive units are made up of a number of parts. If they're different parts for different versions of the 3 that adds a
ton of complexity (and cost) to supply chain.
If on the other hand every single rear motor coming off the line is physically identical, and they handle output differences in software, that's
vastly simpler and cheaper.
And doesn't require any different part number between RWD and AWD either. The car knows what it is, so Motor PN 123 goes in both- and in the RWD it restricts output to X, and in the AWD it restricts output to X minus 10%. Cheaper, easier, simpler.
Ditto front motors for AWD/P.
The binned P motors might get a different PN AFTER the lot sorting, only to insure warranty replacements get a binned part-but that's
after the fact, all the parts inside are the same, but you'd not add a ton of complexity to anything that way.
You keep saying that, but we don't know it for a fact.
We know for a fact there has been
zero factual evidence to suggest or in any way support the idea they're different, and considerable evidence they're the same (including Elon literally stating the
complete drive units are what they lot sort.- which is impossible if they're physically different)
And it's a fact that from a manufacturing, cost, and supply chain point of view it's vastly more likely to be software than hardware.
So for "same" we actually do have a decent bit of evidence....for not same we have literally 0 besides wishful thinking.
Y
The rear motor could be different between the AWD and Performance, but shared between the RWD and Performance. So there is still something to sort.
Could? Sure. Just no reason for it to be, and plenty for it not to be.
I mean, they COULD be batch sorting the seats and putting the ones with the firmest side bolsters in the P too- but we've got exactly as much evidence for that as the motors being physically different.
Lots of coulds. Zero evidence to support them.
