The 60 kWh pack would be a nice luxury and would take driving style basically out of the equation for you but doesn't sound necessary. 3 hours on 40A should be more than enough to get your topped up for those occasional long days. If you have that at work, that's even better since you probably spend longer periods of time there during the day. I would probably use 120 miles as my estimated range on the 40 kWh pack just to be a little more conservative and make sure your trips will fit into that, even with a possible decrease in range (unknown percent) after 8 years under warranty.
It sounds like you'll still have your other gas car so you're set. On the rare occasion where you think it's going to be a problem with the range, you could always switch cars at the start of the day instead of having to meet up later. I'd lean more towards the 40 kWh car unless you think Supercharger access is something you'd want down the road. It's technically possible to upgrade the battery pack years from now (although Tesla says to get the range you want now) but it's unknown if Supercharger access can be added after delivery on the 60 kWh car (if not built in the factory) or added to the 40 kWh car if the battery is upgraded years from now. If you think Supercharger access is something you may want later, the 60 kWh car might give you that flexibility. I'd talk with Tesla in a few months and that should be a little more clear at that point.
Running down to 0 miles when raptors may be out that could be dangerous.
