[poll] Longterm TeslaCam hardware reliability
Discussion in 'The UK and Ireland' started by VanillaAir_UK, Sep 17, 2020.
How has your TeslaCam hardware performed during its use?
  1. I don't use TeslaCam, ie Dashcam/Sentry Mode
    6.5%
  2. It has worked perfectly, no issues - I have recently checked that it is still working
    64.5%
  3. Resolved minor/occasional issue but still using the same media setup
    6.5%
  4. Ongoing minor/occasional issues but still using the same media setup
    12.9%
  5. I had to replace part of my setup (media, adaptor, cable, hub etc)
    6.5%
  6. I replaced all of my setup. I went with same solution again - its a consumable item
    0 vote(s)
    0.0%
  7. I replaced all of my setup and went with a different solution (brand, type etc)
    3.2%
  8. I gave up on TeslaCam
    0 vote(s)
    0.0%
  1. VanillaAir_UK
    VanillaAir_UK Moderator UK and Ireland
    Surrey, UK
    #1 VanillaAir_UK, Sep 17, 2020
    UK Model 3's have been around over a year now, S and X even longer. We should have some reasonable reliability data starting to come through regarding various TeslaCam hardware solutions.
    • How has your TeslaCam media performed during this time?
    • Have you had any problems with it?
    • How often do you use the feature, ie Dashcam and/or sentry mode?
    • How long do you expect TeslaCam media to last - do you treat it as a consumable item or expect it to last duration of ownership?
    • Has TeslaCam failed when you needed it most - failed to record an incident etc
    Longer term (9 months+) users only please, unless you have had a failure. Please ignore software issues.
  2. VanillaAir_UK
    Surrey, UK
    #2 VanillaAir_UK, Sep 18, 2020
    We has a minor fault now resolved.
    It got resolved by
    • using a different formatting option (RMPrep - option 3) to recover corrupt media due to incorrect media removal
    • securely affixing the USB dongle to the underside of the phone shelf to stop it moving around whilst driving
    We use a Sandisk 128GB (High) Endurance device, but if I was purchasing again, the new Max Endurance would be my choice. https://www.amazon.co.uk/gp/product/B084CJ9T2R
    Our USB/SD adaptor is a UGreen dual media adaptor https://www.amazon.co.uk/gp/product/B01EFPX9XA/ and the other slot has a 128GB Sandisk Ultra card that holds our music collection in FLAC format.
  3. NorfolkMustard
    NorfolkMustard Active Member
    M3P w/FSD
    Sentry mode and dashcam active ~99% of its life (activated when I got in the car for the first time on collection day)
    SanDisk Ultra Fit 128 GB USB 3.1... https://www.amazon.co.uk/dp/B07855LJ99
  4. hingus2000
    hingus2000 Member
    London
    My TeslaCam was really intermittent and would need regular re-formatting. I am using an endurance micro-SD card. However since I swapped card readers, it has been flawless - so I think my original card reader (a tiny, thumbnail-style one) was the weak link.
  5. Foucault
    Foucault Member
    UK
    I’ve been using a SanDisk SSD since I picked up the car in August last year and still working fine. I’ve no idea how long it will last but went with a 1TB drive as have nearly 400GB of FLAC music, so about 600GB of space before it starts overwriting data, so should last for a bit. The main reason for buying the SanDisk was that SSD drives tend to be more tolerant of overwriting than USB sticks and it was on special offer on Amazon. If it wasn’t on offer I would probably have bought a Samsung T5 as have been using one for a bit to run windows.
  6. Jason71
    Jason71 Active Member
    Shropshire
    #6 Jason71, Sep 18, 2020
    I was wondering how many people have had a good quality endurance SD give up on them so far? . wanted to know when a good time to preemptively change mine might be. I have a Sandisk 128GB still going strong after 10 months
  7. pgkevet
    pgkevet Member
    mid wales
    Model S 32GB Sandisk USB low profile flash drive 2yrs
  8. Jason71
    Shropshire
    #8 Jason71, Sep 18, 2020
    I just noticed that Sandisk now have a MAX endurance rated at 60,000 hours as opposed to the normal high endurance rated at 20,000 hours its less than double the price (£36 (amazon) for 128gb) which could make it a good investment?
    SanDisk Launches Max Endurance microSD Cards: 3 to 15 Years Warranty
    10 year warranty on the 128gb but I' have not read the small print
  9. VanillaAir_UK
    Surrey, UK
    Please only vote if you have been using the media for longer term.
    This poll is to gauge long term reliability so please do not vote unless you have 9+ months use or have had a significant failure/hardware problem.
  10. VanillaAir_UK
    Surrey, UK
    I spotted those yesterday. High endurance were designed for reliable continuous video recording (such as dashcam and cctv) but did potentially have a finite lifespan (just over 1 year 24/7 for 128GB), but these Max cards extend that to beyond most finance periods, quite possibly vehicle lifespan if not used 24/7 - USB cables/enclosures/corruption likely to be more of a problem.
    Endurance Max would be my media of choice now.
  11. webbah
    webbah Member
    Lucerne, Switzerland
    Never an issue for me. Samsung T5 SSD. I bought this drive knowing it was rock solid with excellent read/write performance. Has been rock solid!
  12. Jason71
    Shropshire
    I could see an argument SSD back in the day when the recording stopped when the device was full and also because the bigger the drive the longer it lasts since the data is distributed to reduce wear on individual bits. But with these Max endurance SD which should out last most peoples ownership of the car is there any good reason to go SSD or anything else anymore unless you want to keep a huge amount of footage for some reason?
  13. NewbieT
    NewbieT Member
    North West
    Samsung T5 partitioned music vs Teslacam.
    Sentry everywhere except home.
    It’s never faulted & still going strong. I don’t even think about it.
