Poll: Model 3 Efficiency (Battery-to-Wheels)
What is your Model 3's lifetime average battery-to-wheels Wh/mile efficiency?
  • 0-159 Wh/mile
    Votes: 0 0.0%
  • 160-179
    Votes: 0 0.0%
  • 180-199
    Votes: 4 1.8%
  • 200-219
    Votes: 15 6.9%
  • 220-239
    Votes: 86 39.6%
  • 240-259
    Votes: 60 27.6%
  • 260-279
    Votes: 26 12.0%
  • 280-299
    Votes: 14 6.5%
  • 300-319
    Votes: 6 2.8%
  • 320-339
    Votes: 2 0.9%
  • ≥340
    Votes: 4 1.8%
  • Total voters
    217
jsmay311
1,051
1,549
Chicago suburbs
Battery to wheels: 1289 mi, 271 kWh, 210 Wh/mi
Wall to wheels: 1289 mi, 311.2 kWh, 241 Wh/mi
I am very happy with these numbers. Love the car!
I have had my Model 3 11 days.
I'm jealous of your relatively small delta between your screen and wall Wh/mile numbers. Only 31 Wh/mile or 15% over the screen number. I'm averaging 54 Wh/mile or 24% over the screen number.
I suppose your relatively high 118 miles/day of driving accounts for a lot of the difference. More miles to spread out the daily vampire losses and longer charging sessions. I'm only driving an average of 51 miles/day.
Can you expound on how you're charging and how you're measuring the kWh from the wall? And is any Supercharging included in your figures?
Ed++
9
Shelbyville, KY
I plug in my Model 3 to my Tesla charger when I arrive at home at the end of the day. Two 60 amp breakers with 6 guage wire. I charge to 80% capacity and have not used a supercharger yet. I never thought about driving more miles per day how it would affect the charging losses, but that makes a certian amount of sense for vampire losses. However for just general losses when charging it should not matter. I measure the output from my breakers with with an effergy E2 Classic energy monitor.
Wireless Energy Monitor E2 Classic with USB port | Efergy
zacyee
72
30
San Diego, CA
~290 Wh/mi lifetime, 1119mi.
Performance Dual Motor with 20" Wheels, typical driving is city. No AP.
Round trip to work is ~270 Wh/mi; when on freeways I typically drive about 75-80 mph in So Cal.
Recently went on trip to watch Space X launch at Vandenburg and averaged probably around 310 Wh/mi for the whole trip.
Overall it's already a lot more efficient than the P85+ and only going to get better as the novelty wears off. If I start doing autocross however, it'll presumably spike up.
Reactions: Brando
Perry
1,050
734
San Jose, CA
~480 Wh/mi lifetime, 1450mi. P3D.
I do floor it all the time though and take it often to the mountains and push it to extremes almost always till battery overheats and goes to reduced power mode with 8 dots. Brakes are almost gone and tires are half gone. Boiled my brake fluid a few times. My full battery range is ~150 miles.
Range anxiety is an issue as the car is always wrong at predicting the remaining charge on destination or which supercharger I will be able to reach. What I end up doing is my own paper calculations because the car is so dumb that it can't calculate the estimated range using historical usage but instead uses rated usage. So lame. You know who's driving (profiles), you have past consumption data for said profile -- use it.
jsmay311
1,051
1,549
Chicago suburbs
I started out last August in the 180-199 Wh/mi range. Then I took some road trips and jumped over 200. Then winter hit and it jumped over 220. Then over 240. Now gradually falling again with the warmer temps.
