My Nokian s do that if it sits foe awhileJoshua,
Did your tests reveal anything as to the vibration felt by many on the first drive of the day that disappears in a minute or two?
Believe it when I see it. Part numbers!! Pictures of the old shafts next to the “new” ones!!FYI. My SA said engineering has shipped a new set of revised half-shafts to my SC to test out on my car. They should be delivered next week. I'll keep everyone posted.
I misspoke when we talked, it’s same part same rev. just a tighter tolerance part from the supplier. The engineering team thinks this should help it.
Afraid they’re addressing the symptom and not the causeWe'll see.
Update from SA:
That's interesting. I don't quite understand how the variability in the cars' geometries somehow trigger some vehicles to have the vibration while others don't, but I could see how a tighter CV joint could reduce the vibration. I'd also be interested in stuffing more grease in the CV joints, as someone mentioned earlier. But, I don't know how much will actually stay inside the critical surfaces in the joint, rather than just flinging to the inside of the boot.
However, manufacturing variability in the half shafts doesn't explain why some cars have it and some cars don't. If that were the case, then I would expect that just swapping shafts once or twice would find a good set and cause the issue to go away.
If they say there's tighter tolerances, where are they getting that info from?We'll see.
Update from SA:
I'm pretty sure the shafts they pull out are not warped or visibly damaged in any way.Lowering car does not resolve the vibration on my car. Shaft angle also doesn’t explain variability with weather. I’m absolute convinced now vibration is significantly less in warmer weather.
Warped half shafts must be a consequence of what’s causing the vibration.
It’s the angle front vs rear. You can feel the vibration change when cruising at around 40mph when you switch suspension height. Raising it makes it works (which ironically is the opposite of how my car behaved when new). With lowering links just on the front of my car and leaving the car in low, the vibration is better on my car, though still noticeable.Lowering car does not resolve the vibration on my car. Shaft angle also doesn’t explain variability with weather. I’m absolute convinced now vibration is significantly less in warmer weather.
I’m not quite sure I follow. It’s not like this is a RWD vehicle where changing front ride hight can effect rear pinion angle. If it was such a simple fix Tesla likely would have corrected it from outset or issued fix by now. I’m thinking its a more complex issue.It’s the angle front vs rear. You can feel the vibration change when cruising at around 40mph when you switch suspension height. Raising it makes it works (which ironically is the opposite of how my car behaved when new). With lowering links just on the front of my car and leaving the car in low, the vibration is better on my car, though still noticeable.
Because they don't have a clue what to do. They have stopped replacing them more than once now to try and correct this issue. I'm not sure why they did it twice on my car, but I wasn't going to tell them not to try.To above poster, if half shafts are coming out true why is Tesla replacing them in the first place?
I’m not saying that the root cause is ride height. I am saying that ride height does affect the vibration. It’s easy to test, too.I’m not quite sure I follow. It’s not like this is a RWD vehicle where changing front ride hight can effect rear pinion angle. If it was such a simple fix Tesla likely would have corrected it from outset or issued fix by now. I’m thinking its a more complex issue.
You’re in the wrong thread. This is nothing to do with the tire-shredding issue.This is the root cause and explained in good detail here
Eliminate Inner Tire & Premature Half-Shaft Wear On Tesla X/S!
Finally you can properly align your Tesla Model S or X to completely eliminate inner rear tire wear and premature half-shaft wear!n2itive.me
You obviously didn’t read it because it talks about half shaft issueI’m not saying that the root cause is ride height. I am saying that ride height does affect the vibration. It’s easy to test, too.
That article talks about the shudder in the previous generation S/X half shafts. This is a new issue, possibly related, but somehow different. I agree that reducing ride height does seem to mitigate the issue. However, so does turning off the front motor. So, I don't know what that means.You obviously didn’t read it because it talks about half shaft issue
