I can't edit a post once I sent it? I forgot to mention a gas station with a Honda generator can pump gas until it is out of gas. Try running a supercharger off a Honda generator. (Hint: you can't.)
Good point, yet I will say there are a LOT more gas stations than charging stations and the probability of being about to drive to another location just outside of the area where I can pump gasoline is more likely than having to drive 50 + miles to a charging station that works. Depends on the location of course. I would also feel more confident that I can fill the car in about 3 minutes as compared to sitting in one location for 30+ minutes hoping the electricity will stay on and give me more mileage.How well do gas pumps work without electricity?
But the other side, if there is a traffic jam, EVs do better at slower speeds, especially if you turn the AC off.
Just a side comment; why is it a binary decision? Depending on what is going on, I might just decide to take a motor bike.Given the recent seismic activities in SoCal, I’ve been thinking about a plan in case of emergency. Would it be easier to find gas than electricity after an earthquake?
Locate solar powered SC's and GTFO of townGiven the recent seismic activities in SoCal, I’ve been thinking about a plan in case of emergency. Would it be easier to find gas than electricity after an earthquake?
Which is why you should plug your car in EVERY night to 90%When the big one comes, not sure that my car will be accessible as I assume that part of the garage may come tumbling down or at least, the garage door will be inoperable. Also, roads will be blocked as some overpasses will collapse. Finally, its likely that the parts of the grid will be down, so one can only go as far as the current charge will allow.
I got solar and powerwalls so as long as my home isn’t damaged to the point of being uninhabitable I’ll probably take my chances with the Teslas. Would actually be able to barter rides for supplies if it came to that. If my home is destroyed then I’m gambling that there will be at least a 110v outlet somewhere within 200-250 miles.
