Poll: What is the 'something special' for Roadster owners from Tesla in 2014?
Discussion in 'Roadster' started by pharma5, Dec 29, 2013.
Tags:
From Elon's hints, what 'pretty cool' thing will Tesla do for Roadsters in 2014?
  1. Fix for charging bug (80A pilot signal compatibility) *only*.
    2 vote(s)
    2.1%
  2. Fix for charging bug and Adapter to use Model S HPWCs
    4 vote(s)
    4.2%
  3. Fix for charging bug, Adapter for Model S HPWCs, and HPWCs at Supercharger sites
    32 vote(s)
    33.3%
  4. Improved brakes
    0 vote(s)
    0.0%
  5. Some type of PEM upgrade (e.g., liquid-cooled)
    6 vote(s)
    6.3%
  6. Some type of motor upgrade
    3 vote(s)
    3.1%
  7. Some type of battery pack upgrade (e.g., using newer cells)
    38 vote(s)
    39.6%
  8. Something else entirely
    11 vote(s)
    11.5%
  1. pharma5
    pharma5 Roadster F#25, Model 3 #36xx
    central NJ
    #1 pharma5, Dec 29, 2013
    From Elon's comments at TESLive and Twitter: "We are going to do something special for Roadster owners next year. I can’t say what that is, but I can say that it will be pretty cool."
    As we enter 2014, what do you think it is?
    EDIT: Please vote from the options above - thanks to all for participating!
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I hope it is #3. But only some Tesla employees know for sure...
  3. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    #1, the 80amp pilot signal bug, is already fixed...
  4. pharma5
    central NJ
    Absolutely, as reported here on TMC. :smile:
    But do you think that will be all?
  5. bonnie
    I don't think that's it, no. I hope not! That wouldn't be exciting or cool or special. That would only fall under the category of 'long time coming'.
  6. hcsharp
    hcsharp Active Member
    Vermont
    I didn't vote. The 80A pilot bug has already been fixed and it's not 2014 yet. I can't vote for the adapter choices because it would mean all my hard work would go down the drain unless they do a crappy job like they did with the J1772 adapter. I think there will be a motor upgrade but that will also require a PEM upgrade and it won't let me vote for both. New brakes are a possibility but won't be the only thing. Improved pack with newer cells is a possibility especially if they offer a motor/PEM upgrade. I can't vote for "something else entirely" because I think the real answer is a combination of more than one item and not entirely something else.
    I'm almost worried that it will, in fact, be 'pretty cool' because we have 2 kids in college and probably can't afford it.:crying:
  7. 772
    772 Member
    Iowa
    New battery back that can use superchargers!
  8. pharma5
    central NJ
    Apologies HC, feel like I bungled including an option for "Some combo of PEM, motor, and/or battery pack upgrade".:redface:
    Mods, is there any way you or I can edit that option in as next-to-last choice listed?
    Absent a tweak to the poll options, I'd recommend voting for whichever item you think would be the primary driving force or most prominent item for such an upgrade. (I'd also note the poll is asking what we think it will be vs. what we want, although people can and will certainly vote however they want.:wink:).
    For the adapter choices, in my head I like to consider the possibility that the design could still be sourced/licensed from you... the poll does not limit where it comes from...
  9. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    THAT is my fervent wish, although almost certainly, it will require a new pack, new PEM, new MS-style inlet. Seems too good to be true (and probably too expensive to justify, as Henry fears above)!
  10. ChadS
    ChadS Petroleum is for sissies
    Yeah, I'm pretty darn confident that Supercharger capability isn't on the table. Too much has to change. Too expensive for so few cars.
    My biggest hope is for an OPTION to buy a future battery pack (no need to make it now!) at far lower prices. That should help with Roadster resale values AND give Model S buyers more confidence.
  11. ggr
    ggr Roadster R80 537, SigS P85 29, M3P 80k
    San Diego, CA
    I think it will be an announcement that there will be something cool for Roadster Owners in 2015! ;-)
  12. adiggs
    adiggs Active Member
    Portland, OR
    I think that ChadS has the right way of valuing what gets done for Roadster owners. It's not how many of the widget can be sold to Roadster owners - it's what it says to the next generation of owners about how their car can evolve later in time. We can wait several years for the initial Model S fleet to age, and then come up with something that seems straightforward like a battery upgrade, and just hope that it comes along, and learn THEN how upgradable these early Model S's are. We can all think that it's straightforward and easy to upgrade the Model S's, and I think we can agree that on the surface, it should be easier than something like that would be for the Roadster.
    But if Tesla steps up in 2014 with something of that scale for the current Roadsters, the ancillary goodwill across the entire Tesla owner community will be huge. Like move-the-stock-price huge.
    I'm voting battery - use the current battery box for a Roadster and "fill" it with Model S chemistry batteries. There will be firmware updates required I'm sure, but the change in chemistry takes the roadster from ~50 to 80 kW sized battery. Do that, and now its running around out there in the wild for everybody to see - it's not just theory, it's real. (Crazy notion that the Roadster battery has almost as many 18650 cells as the Model S85).
    That's what would be exciting and cool to me. A new brake option - not exciting or cool.
    What I really want to see is the combo talked about by others - updated battery chemistry, liquid cooling for the PEM, maybe liquid cooling for the motor, DC hardware bypass, Model S style plug, firmware that keeps everything happy, and Supercharger access. That would be a technology game-changer, not for what it does for the Roadster owners (all 2500ish of us), but what it says can be done for the Model S. I also know that it won't be easy and it won't be cheap.
    The straight battery chemistry swap, which also won't be cheap, would still fall into the exciting and cool. Even if the performance doesn't change, charging to ~170*1.6 = 272 Ideal Miles for a standard charge each day; that'd be cool.
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Upgraded battery pack would be my strong preference. However I expect nothing.
  14. Tesla 940
    Tesla 940 Member
    Long Beach, CA & Taos, NM
    I read/seen Tesla's announcements and "confirmed" rumors for years regarding the Roadster and the Model S. I've rarely been "excited" - rather, I've been disappointed maybe because I had my hope up too high (if that is possible). Therefore from my perspective I doubt I will find the announcement to be "exciting". As for the battery - they have to do something and since the original batteries are no longer available using the Model S cells or even the next generation is simply something they HAVE TO DO. Of course Tesla could use this as their "exciting" announcement. Excitement is in the eyes of the beholder!
  15. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    Upgraded battery pack and the option to use the old pack as a battery backup or UPS for your house.
  16. adiggs
    Portland, OR
    Ok Sparrow - you're right, the ability to reuse the old battery as a house UPS - THAT would be cool. I'm already thinking about how to pull something like that off at my house, and ~50 kWh worth of battery would provide a big assist. Very nice.
  17. bonnie
    Okay, now we're talking. At one point I'd talked to someone at Tesla about this. I'd LOVE to recycle my own battery pack into backup power for my solar system when it's time to replace my battery. What a great story to be able to tell.
    And if that replaced battery just happened to offer greater range, BONUS!
  18. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    It's fixed but was told it still hasn't rolled out yet. Should be soon though.
  19. dsm363
    Nevada
    A 300 mile highway range pack should be possible and would be awesome.
    Adding HPCs to Superchargers would be nice as well. Don't expect either though.
  20. Marius
    Marius Member
    Berkel en Rodenrijs NL
    Indeed, Tesla will not develop all kind of features for 2500 Roadsters.
    They will only develop something that helps sales for model S and future models. So only replacing existing battery cells with Model S cells brings an extension of range of about 125 miles. It seems to me it can easily be done with a small benefit for Tesla at a reasonable price.
    Big message will be then: Buy a Model S because in 5 years time you will be able to make a 500 miles range upgrade as Tesla shows with Roadster upgrade.
    Supercharging capabilities for Roadster is simply from marketing point of view not interesting.
