As you said, my assumption of the braking force scaling with tire width probably isn’t correct as presumably the contact patch is the same area for the same pressure. But, fortuitously, I turned out to be close anyway. The PS4S tires are a lot stickier! 1.15g!
The sub-100 distances reported elsewhere...I wonder whether they are doing a stop from 70 like you are? There is some initial heat up of the tire I suppose, if you start from 70. It’s 36% more energy to dissipate. Doubt it makes a difference, but suppose you could try stopping from 65, to see if there is any change.
Looking forward to comparing whenever I finally get my P3D+! I’m sure it will stop faster, since it has those bigger brake calipers...and we know that’s what really matters here! Depending on how it does, might be interesting to swap wheels.
