Here is what I just posed in the other thread.
Had a comparatively bad drive in the morning dropping off kids.
Its the same route I've done 20x over the last month with FSD - there is some variability, even with same release. So, have to wait for a few more drives for a reliable report.
- On the first right turn from stop, suddenly jerked the wheel to the left - so got disengaged. While I've written a lot about the jerkiness when turning right from a stop, none of the wheel action has been this much.
- At an intersection where the side roads have stop signs, the shoulder starts out very broad and then narrows. On rainy nights, the car had got confused once and gotten into the shoulder - but today in broad day light on a dray day, the car decided to use the shoulder rather than the lane it has taken every day. Second disengagement.
- At a signal when going straight, the car decided to go only 100 ft or so and then stop. Not sure what happened - had to take over. Unfortunately hadn't turned on the camera. So, third disengagement.
Apart from the above 3, had some usual disengagements.
- At a traffic signal where the car needs to turn right, it is supposed to be no-turn on red (the signal says "right turn signal"). But most people turn and honk if someone doesn't. Had to disengage here because, the car stopped well short of the intersection and for me to even press the go pedal, I need the car to creep. Not sure we can control the creep by pushing the go pedal, without the car deciding to take off at the wrong time.
- Roundabout that is not in the map
Other observations ..
- The car seemed to keep more to the right on unmarked roads. Could be just the normal variability.
- When finishing the drive at home, the car came closer to the curb. New behavior or just by chance ?
- Turns when already moving have always been variable. Some smooth, others jerky. Today all the turns seemed jerky.
So, on the basis of this one drive, I've to say 10.5 was worse than 10.4. But need more observations to confirm.
