My doors don't seem to detect obstacles properly. I wanted to get feedback from other X owners ... is this normal?
Driver door problem:
Falcon wing problem:
Trunk problem:
For the Trunk: Manually raise it to a max safe level. Then hold the close button until you hear a long beep. This will set a new max height. OMG, that made me cringe!!
On the front doors I suspect those filters do not reflect well enough to be seen as an object. Cover them with foil, and test that result.
For the FWD, that object is probably too narrow to be seen, so I would adapt and find a new way to enter that door. Maybe Summon it back a couple feet?
@Chanman I don't mean to sound like an a-hole, but you really should have a good read of the manual, where it helps understand how the car opens/closes the doorsView attachment 169731
I already sent Tesla an email suggesting this ([email protected]) - maybe you can send one too to encourage them to make a change?I plan on turning my auto open off when I go to a parking garage. It would be nice if you could set the default mode (auto or off) based on location. I would probably have it off in most places but ones I trust, I would want to be in auto mode.
