Poorly insulated corner
Discussion in 'Model S' started by Chan, Jan 27, 2015.
Tags:
  1. Chan
    Chan Member
    Belgium
    Hello Hello,
    When I drive in cold weather or late at night my left hand always start to feel cold.
    First I thought it was the window or something, but later I discovered that the cold air just comes in from that little triangle corner that I depicted in the attachment. Is somebody else experiencing this?
    Because otherwise I know I just have to contact SeC.
    Kind regards,
    Frederik
  2. Chipper
    Chipper Active Member
    Chattanooga, TN
    Others have experienced this also. Just contact SvcC and let them know. They have a fix for this.
  3. Chan
    Chan Member
    Belgium
    #3 Chan, Jan 27, 2015
    Called and they will idd modify it.
  4. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    Had this after getting folding mirrors. Was fixed by tweaking the angle of the small triangle glass and adding more filling/packing material along the edge (as I was explained). Will be fixed under warranty.
  5. Fezzik
    Fezzik P67429
    Lincolnshire, IL
    Same here on my p85d. Had a really cold draft coming in and SC fixed it.
  6. rpavlicek
    rpavlicek ***** Neophyte
    Santa Clara, CA
    Can anyone explain how they fixed it?
  7. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    The cars are very sensitive to fit on that window. You'll notice that since we have a frame-less door, the windows lower slightly when you open and then raise again when you close the door. This is to get a good seal. Then you'll realize that the little triangle window is stationary and can't benefit from this. Mine even leaks a tiny bit if I take it through a high-pressure wash.
  8. JPP
    JPP Active Member
    SF Bay Area, CA
    There is a TSB fix for these windows for both air and/or water leaks. Just had mine done at a routine 24k service last week.
  9. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    I started a thread about the TSB here:
    Service Bulletin for Wind Noise Issue on P85D
    But I had not yet heard from my service advisor that the parts for the TSB were available. It sounds like they must be.
  10. Jaff
    Jaff Active Member
    Grimsby, Canada
    I tried to book an appointment for this TSB to be looked after at the Mississauga store...I was advised that the parts for the fix haven't arrived yet.
  11. scottm
    scottm Active Member
    Canada
    Duct tape.
  12. sundoc
    sundoc Member
    Ontario, Canada
    Mine was taken in for a couple of things today... all minor, one being the wind noise (and cold air) from both sides. The fixed version is worse now :/
    Going to call them tomorrow or the next day.
  13. Andyw2100
    Ithaca, NY
    Do you know if they perhaps just tried to fix it without knowing there was a specific TSB, and thus may not have had the TSB parts, and that might be why it's worse now, or do you know for a fact that they did use the TSB parts? I ask because upthread someone else indicated that their service center also said they didn't have the TSB parts yet, and it would obviously be better for all of us, including you, if what didn't work was just some random attempted fix by the service department, as opposed to the actual TSB repair that made things worse.
  14. sundoc
    sundoc Member
    Ontario, Canada
    On my Service invoice it reads:
    Corrections: Install LH And RH Front Fixed Glass Seals
    Removed both front door panels and installed new fixed glass seals. Performed validationroad test.
    Parts Replaced or Added
    Part Quantity
    FIXED GLASS SEAL RH (1046148-00-A) 1FIXED GLASS SEAL LH (1039364-00-A) 1
    So I'm not sure if thats from the TSB but the 'new fixed glass seals' makes me think it may be.
    I'll check the passenger side tomorrow and see what comes of the whole thing.
  15. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    No problem on my P85+. Do you hear any wind noise from that area?
