Porsche's new 350kW EV charging station
Discussion in 'Charging Standards and Infrastructure' started by Takumi, Jul 14, 2017.
  1. Takumi
    Takumi Member
    IL
    • Informative x 2
  2. vrykolas
    vrykolas Member
    The Colony, TX
    Where is this located?
    What type of connector is it? Which standard (or is it proprietary)?
    Does it "charge" (cost?)? (I don't a UI for payments)
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    I guess you didn't read the link?
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
  5. RubberToe
    RubberToe Supporting the greater good
    El Lay
    Built in lightning protection? Might make for a good 4th of July...
    RT
  6. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    It's in Germany... now they need to make a car that can use that charger
  7. stopcrazypp
    stopcrazypp Well-Known Member
    Spec is 1000V and 400A. So basically CCS 2.0. The connector profile can be the same as CCS given modest current boost (wires inside have to be updated, and perhaps it needs liquid cooling). The Tesla connector already goes to 370A.
    This requires the new 800V battery pack that Porsche will be doing. It'll be very interesting to see how they handle backwards compatibility to 400V chargers on the car.
  8. David99
    David99 Active Member
    Brea, Orange County
    800 Volt batteries are the only way to significantly increase charge speed. Tesla will eventually do this as well. Maybe as soon as with their all new Model S next year. The 350+ Ampere on current Superchargers is already causing a lot of heat at the connectors. Doubling the Amps would quadruple the losses and heat build up on all connections. Doubling the voltage causes no extra losses at all. By increasing the voltage you can get more power while having the same losses. It makes sense to go to a higher voltage.
  9. GarrickS
    GarrickS Member
    Inglewood, CA
    "Porsche claims that it already has the backend to support 350 kW charge rate, it can currently charge at 50 to 150 kW until vehicles can support higher charge rates."
    So Porsche is the first to install a 350kW EVSE that does not actually support 350kW.
  10. mspohr
    mspohr Active Member
    Porsche plans network of 500 fast chargers for U.S.
    More news on Porsche's plans to roll out their superchargers to 189 dealers plus 300 additional locations in North America supposedly by the end of 2019. They will charge for a charge but are vague on the price.
    They seem to have figured out that they will need a battery at each site to support the high charge rate (and probably avoid high demand charges from utilities).
  11. gjunky
    gjunky Waiting for the Model ☰
    Scottsdale, AZ
    How do they count these? 500 locations with one charger or 500 charge poles or something else?
    300 locations across the US with a single charger won't help much unless they don't plan to sell a lot of their Mission Es
    Not sure how a US Tesla would charge from a CCS
  12. mspohr
    I think it's 500 fast charger stations. Sounds like most would be a single station at a single location. They are going to tell their dealers they have to have it installed by the end of 2019. They are "exploring" working with ChargePoint, EVgo, etc. on the 300 other stations but don't hold your breath. Maybe 2020, maybe later. (Don't plan a trip for a while.)
  13. gjunky
    Scottsdale, AZ
    No need. We have our own :)
  14. Jeff N
    Jeff N Active Member
  15. Jeff N
