I know this seems to be a controversial topic here for some reason, but I'm interested in exploring how it might be possible to use foldable portable solar panels to charge the car. I know there are a lot of reasons that this may be a bad (and certainly a cost and time inefficient) method of charging, but I just want to focus on how I might go about this in theory if I wanted to try.
The (hypothetical) scenario I have in mind is that I'm doing some long term car camping out west in a Model 3 LR AWD. I may be doing long day hikes in an area with pretty much constant sun, and may be sleeping in a campground with no available power at night either in the car or in a tent relatively close by.
I know it would be relatively easy (but not cheap) to fit about 1-1.5 kW DC worth of foldable solar panels into the trunk while still having plenty of room for camping and other gear.
This is an example of a folding panel in the right size/power range (assuming two to three of them). I'm sure there may be better ones out there, but it's just for example. At 1.5 kW, you could theoretically charge at 3-5 mph, depending on charging losses. With the summer sun, that could be 30+ miles per day and 60+ over a two day hiking trip.
So, even though it's not really a very practical option, I'm interested in how I might pull this off.
- What type of inverter would you use?
- Would the most efficient/simple route be solar panel -> inverter -> 120V outlet -> mobile connector?
- Will the car handle potential sudden variations in amperage without stopping charging?
- Will the car be able to automatically start charging again if the power cuts out (due to passing clouds, etc.) and comes back?
- Are there any other technical roadblocks I'm missing?
Thanks for your input! Again, I know this isn't a practical (or cost effective) method to charge a car on this sort of trip, but it's an interesting thought exercise!
