dtich
#P708
Finally, as an interesting aside to this whole discussion, there is apparently something in the geometry of the suspension that changes the wheelbase distance slightly when the suspension height changes. I happened to have my foot on the brake when I was playing with suspension heights in the garage the other day; after changing height from Normal the Very High I lifted my foot from the brake and the car lurched slightly. The transmission was in Park the whole time. This is repeatable.
this makes sense to me. raising the suspension changes the angle that the struts make with the axles (higher reduces this < slightly, inverse with lower), if you are keeping the wheels from turning even the slightest amount during this, there will exist a force differential that will settle once the calipers relax (parking brake may not hold as firmly as main brakes and allow a slight inching to lockup). i would imagine that this is not a change in wheelbase per se, which would involve relative axle movement, probably not possible, but just a slight tire rotation due to changes in angular force from the struts in a different position.... 2¢.
