Sentry Mode operating at home in the garage - 18 events overnight. Never happened before, Sentry disabled at home (in the car menu)
Battery drain. Trips showed 8kWh used in 45 miles (3 short trips), but in the same 48 hour period (just after updating the software) the battery dropped from 60% down to 36%, which is about 18kWh. Much more drain than usual (2022 M3 LR).
General question - do you turn climate off between uses? I started doing this because I would often hear the system working several hours after the car had been parked in the garage (this was before the update)
