You are implying that NHTSA found a safety defect and negotiated with Tesla to correct it with the retrofit.
After more careful reading, that's not just what I'm implying, that's what I believe almost certainly happened. Let's look at the facts as we know them. There were two incidents, and the NHTSA covers them separately. No-one else is looking at the statement that way, but it's very instructive when you do.
First, the
NHTSA investigation process includes frequent contact with the manufacturer:
3. Investigations:
Investigations are conducted in two phases: the Preliminary Evaluation and the Engineering Analysis.
Preliminary Evaluation (PE)
Most PEs are opened on the basis of information submitted by DAD, but they may be opened on the basis of other information as well. During the PE phase, ODI obtains information from the manufacturer (including, but not limited to, data on complaints, crashes, injuries, warranty claims, modifications, and part sales) and determines whether further analysis is warranted. At this stage, the manufacturer has an opportunity to present its views regarding the alleged defect. PEs are generally resolved within four months from the date they are opened. They are either closed on the basis that further investigation is not warranted, or because the manufacturer has decided to conduct a recall. In the event that ODI believes further analysis is warranted, the PE is upgraded to an Engineering Analysis.
Engineering Analysis (EA)
During an EA, ODI conducts a more detailed and complete analysis of the character and scope of the alleged defect. The EA builds on information collected during the PE and supplements it with appropriate inspections, tests, surveys, and additional information obtained from the manufacturer and suppliers. ODI attempts to resolve all EAs within one year from the date they are opened, but some complex investigations require more time. At the conclusion of the EA, the investigation may be closed if the manufacturer has notified the agency that it will conduct a safety recall or if the agency has not identified a safety-related defect. However, if ODI believes that the data developed indicates that a safety-related defect exists, the ODI investigator prepares a briefing to be presented to a panel of experts from throughout the agency for peer review. If the agency panel concurs with ODI’s recommendation that a recall should be conducted, ODI notifies the manufacturer of the panel’s concurrence and may, if appropriate, provide a final opportunity for the manufacturer to present new analysis or data. ODI then sends a Recall Request Letter to the manufacturer.
OK, so the process includes discussions with the manufacturer. Let's look at this specific case. The following paragraph from the
NHTSA statement says alot:
Tesla performed a series of tests reconstructing this incident and determined that a similar shaped object contacting the forward edge of the HVB could be "tripped" and potentially penetrate the HVB case. As the object's opposite end digs into the pavement, vehicle momentum causes the object to impart upward force into the case, described by Tesla as a "piking effect". Tesla's testing reproduced damage similar to that seen in the Tennessee incident, and also showed that a change in ride height strategy, which was implemented in Nov. 2013 via a telematic software update to prevent the SVs lowering at legal roadway speeds, mitigates the risk of battery compartment penetration when a three-ball hitch is struck.
1. The NHTSA knew about the tests Tesla conducted before Tesla published some of them in their blog (NHTSA statement came out first).
2. The NHTSA agreed that the change in ride height already conducted (5.8 I believe) mitigated the fire risk.
So, there are movies we haven't seen that show that running over the trailer hitch with a low ride height will indeed damage the battery enough to cause a fire. And there are movies we haven't seen that show that increasing the ride height reduces or eliminates that damage.
Those are facts. The logical conclusion from the wording is that since Tesla already issued what was effectively a recall that reduces the risk to acceptable levels, the NHTSA did not feel it necessary to insist on making what was already done a new official recall. You may come to a different conclusion.
Let's look at the investigation into the second incident:
The object struck in the Washington incident was not identified. More severe damage to the incident vehicle and the unknown shape of the object raised concerns regarding the effectiveness of raising the ride height for objects other than a three-ball hitch. In a Mar. 10, 2014 meeting with ODI, Tesla stated it would conduct a free-of-charge service campaign to modify the SVs by adding three new components to the vehicle's undercarriage to protect the HVB. A low-hanging transverse member and an additional underbody plate would be mounted forward of the HVB case and a third plate would overlap the leading edge of the case. Testing conducted by Tesla demonstrated that these modifications improved protection from debris impacts.
The NHTSA saw the results of testing performed by Tesla before those were made public, so again they were in communication. Matter of fact,
they conducted a meeting on March 10! And during that meeting Tesla said
it would conduct a free-of-charge service campaign to modify the SVs. And, Tesla showed the results of their testing that these worked.
Neither of us were at the meeting between between Tesla and the NHTSA, but it seems obvious to me that what was happening can logically be described as a negotiation. Maybe the NHTSA said they would move the investigation into the EA phase. Maybe Tesla was simply being proactive in conducting the EA for the NHTSA, and providing a solution, in the hope that the NHTSA would not characterize the result as a recall. We weren't there, so we can't say for sure, but it seems far more likely that the discussion was more of a negotiation than a "well, here's what we've done, now we'll shut up so you can decide what you want to" kind of thing.
Now, time for the way-back machine. Remember back in Jan when
Elon said that their over the air update and swapping out of 14-50 adapters was not a recall because "no Tesla vehicles are physically being recalled" () or
Jerome Guillen saying:
"calling Tesla’s fix a “recall” was outdated because it did represent a physical repair but rather a software update conducted wirelessly while the owners’ cars were parked in their garages. “We are going to be having some discussions about the appropriateness of using a word that has no physical sense,” Guillen said.
And now we have physical vehicles coming in to be modified and somehow that's not a recall? Well, turns out the NHTSA isn't making a unique exception for Tesla. As
this Bloomberg story says:
Earlier this year, the agency and Chrysler Group LLC clashed over fixing 2.7 million Jeep Grand Cherokees for gasoline tanks that can leak in a crash. The agency says 51 people have died in post-crash fires.
Chrysler initially challenged a government-requested recall, which would have set up a rare public hearing and court case, before agreeing to a “voluntary campaign” to provide more protection in rear-end collisions.
So, whether the terminology is "voluntary campaign" or "retro-fit", the NHTSA only cares that the manufacturer is doing something that appropriately reduces the risk without charging the customer directly for the fix.
Kudos to Tesla for getting in front of the situation, especially after Musk himself said that the car did not need to modified.
