Possible to use Tesla Wall Charger to charge our CMax Energi as well?
FlyErik
52
59
Minneapolis, MN
We plan to have a Tesla 240v wall charger installed in our house and we also own a Ford CMax Energi. Does an adapter exist which would allow us to plug the CMax in when we're not charging the Model 3?
Info seems very scarce online so I haven't had any luck finding the reverse of the adapter we all got with our Model 3s.
Thanks in advance for any guidance!!
Erik in the Bay Area
saltsman
201
237
College Station, TX
It'll be cheaper to have the Tesla charger (sounds like a hpwc) installed with a 240v plug adjacent.
Why not just install a NEMA 14-50 plug and use the Tesla Mobile Connector and something that does J1172? Swap as needed. Or just install two 14-50 plugs and leave both plugged in?
Adapt at the plug end, not the connector end.
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,250
3,520
San Diego
Hpwc allows 48 Amp charging and is a more durable device. And, 14-50 plugs are not designed for repeated plug-in and plug-out (Will need to replace the outlet)... That being said, if neither matters, yeah get a plug and switch off evse's... Still recommend two plugs or a hpwc plus a plug
TT97
2,168
2,894
Los Angeles
Does anyone have two HPWCs daisy-chained with one using the JDapter? Will the units still load share if it is not two Teslas?
Az_Rael
5,602
8,749
Palmdale, CA
The other option is to install a regular J1772 EVSE and use Tesla’s adapter to charge the Tesla. That would probably be cheaper than buying a wall adapter and a J-adapter. Also, other companies make chargers with more features than Tesla does, including the ability to schedule charging and track energy usage.
Reactions: gaswalla
miimura
5,989
5,567
Los Altos, CA
Yes, this configuration works. Others have posted on TMC that they do that. One specific case I recall was a Model S and a Bolt EV. You can also buy a Wall Connector with the connector changed to J1772, sold by the same company that makes the JDapter.
Reactions: TT97
