possible to wire up a 110v plug here?
Discussion in 'Model S: Battery & Charging' started by gnychis, Feb 7, 2014.
  1. gnychis
    gnychis Member
    Boston, MA
    I am trying to find a way to charge my car (even at 110v rate) outside of my work place. Relatively temporary until we move (about 2 months from now). I found this outside near the back of our building:
    Anyone know if this wire is safe and/or high enough gauge to be able to pull 110 and maybe around 10amps? Clearly, I have little clue to do this myself. Just curious at the high level if anyone knows this is worth me pursuing or not.
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Those look like irrigation wires to operate the water valves. They are usually 36V AC with very low amperage, so NO.... you cant use this.
  3. gnychis
    gnychis Member
    Boston, MA
    Great, that's the high level feedback I was looking for. Thanks Lloyd!
  4. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Wire gauge looks ok for 10A from the picture. I think I can read 14 AWG on one of them. But you would have to check this. The writing is obscured in the picture.
    Looks like that could be low voltage DC for landscaping lighting.
    And the fact that one of the wires is just bare and hanging up there makes me wonder if you even want to deal with that.
    If it were me I would look for a better plug in spot, some street lights have j-boxes in the bottom you can get at with a screwdriver. And buildings should have some exterior wall plugs, you just might have to park in back though.
  5. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Lloyd is right, bunch of reds with one white is standard low voltage irrigation system.
  6. gnychis
    gnychis Member
    Boston, MA
    It makes sense. It's basically around our grassy/green area, so I would bet on it too! I'll check out some of the taller parking lot light posts, ElSupreme, that's a good idea.
    Also, we have an unused air conditioning system in the back of our building. It is a bit far from a parking spot, so I may need an extension cord:
  7. ElSupreme
    Atlanta, GA
    Make sure the voltage is appropraite. Most commercial locations use 208 VAC for lighting, but some is 277 VAC. I would suspect the UMC would work fine for 208, but I wouldn't use my UMC (or car for that matter) to test 277VAC.
  8. SBerg
    SBerg Member
    Solvang, CA
    You might want to talk to the owner of the building/outlet. We already had one owner get busted for "stealing" electricity, and without consent, that is what it is. If the owner is cool, go for it.
  9. Cosmacelf
    Cosmacelf Active Member
    San Diego
    Well, you would have to get an electrician to wire up an electrical plug to that on/off switch box and disconnect the AC unit. I doubt the building owner would be very interested in doing that.
    Do you need work charging? Normally you don't need work charging with a Model S.
  10. FlasherZ
    Some small business owners choose to charge at work instead of charging at home, for tax purposes. :)
