Post Software Update Checklist
Discussion in 'Model S: User Interface' started by tomas, Jun 10, 2014.
  1. tomas
    tomas Only partially psycho
    Oct 22, 2012
    #1 tomas, Jun 10, 2014
    Firmware update "Best Practices" for MS owners to check for/mitigate known anomalies:
    * Leave car alone while updating. Trigger update, leave, walk away.
    After update is complete:
    * Reboot both screens (hold L+R thumb scroll bar until center screen reboots, hold L+R top thumb buttons until dash screen reboots).
    * Check bluetooth pairings. If existing pairing doesn't work, delete and re-pair.
    * Check side mirror auto-tilt. If it was "forgotten", re-set tilt and save.
    * Check regen braking and steering setting. Toggle/reboot/toggle option if either seems incorrect.
    * Check that suspension lowering setting is correct.
    +++ Please post adds and corrections, I will edit/accumulate in top post +++
    +++ Mods, should this be sticky? +++
  2. ZBB
    ZBB Emperor
    Feb 27, 2013
    FWIW, Here's my experience:
    - I've done the reboot (both screens) on about half of my updates. Can't really tell if it helps (but it can't hurt...).
    - I've had BT pairing fail once after an update (bad call quality was the sign). But its failed a couple other times well after an update. Delete and re-pair always fixes issues.
    - Never had side mirror auto-tilt be forgotten after an update.
    - Never had regen issues after an update...
  3. Mike_Schlechter
    Mike_Schlechter Model S - P457
    May 21, 2010
    Weston, CT
    I noticed when I got 5.9 the second time (strange enough that I got it twice) that I had to set my auto-lowering for the air suspension again.
  4. Todd Burch
    Todd Burch Electron Pilot
    Nov 3, 2009
    Smithfield, VA
    I never reboot after an update, and haven't had any issues after an update either.
    What I *do* do, however, is I leave the car alone for about 15 minutes when it's updating. Trigger the update, then leave and walk away.
  5. SarahsDad
    SarahsDad Member
    Aug 2, 2013
    I don't reboot on every update but back on 5.8 my steering changed from Sport to Normal and my regen changed from normal to low even though the touchscreen toggle appeared unchanged. A simple reboot didn't work - I had to toggle steering back to normal, and regen back to normal, then reboot again before it worked.
